Cannot Calibrate Water Level Sensor
Posted: Fri Mar 04, 2016 1:16 am
by hnnhflns
As the title suggests, we cannot get the water level sensor to calibrate. We have read through every water level sensor post for the past 2 years, but still nothing works. Setting the 0 value for the sensor goes off without a hitch, but when the sensor is lowered into the water to set the 100 value, there is no reading on the sensor (ie the value does not change as the sensor is submerged.
There was a slight hiccough with the SoftwareSerial library that was not allowing the code to compile at first, but updating SoftwareSerial.cpp solved that problem. I saw another suggestion to update or change the RA_Joystick.h, but I haven't been able to find that library in the RA Program Files.
Any other suggestions or solutions? We are trying to set-up our ATO system.
Also, where is the RA_Joystick library located in the Program Files so that I can update it?
Reinstalling the Arduino software did not update the libraries, it only set us backwards so I have to go back and at least update the SoftwareSerial library.
#include <SoftwareSerial.h>
// Define Relay Ports by Name
#define DT_Pump            1
#define Heater             2
#define UV                 3
#define Swabbie            4
#define Ozone_Pump         5
#define Skimmer            6
#define Fan                7
#define Frag_Tank          8
#define Kalkwasser         Box1_Port1
#define Desk_Can_Lights    Box1_Port2
#define DT_White           Box1_Port3
#define DT_Blue            Box1_Port4
#define Powerheads         Box1_Port5
#define Refuge_Light       Box1_Port6
#define Moonlights         Box1_Port7
#define ATO_Pump           Box1_Port8
// Does not need to be global.
// unsigned long ATOUpdate=0;
static time_t LastATO=millis();    // For de-bounced ATO
    ReefAngel.AddORPExpansion();  // ORP Expansion Module
    ReefAngel.AddPHExpansion();  // pH Expansion Module
    ReefAngel.AddMultiChannelWaterLevelExpansion();  // Multi-Channel Water Level Expanion Module
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.FeedingModePortsE[0] = Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePortsE[0] = Port8Bit;
    ReefAngel.LightsOnPorts = Port8Bit;
    ReefAngel.LightsOnPortsE[0] = Port3Bit | Port4Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port4Bit | Port6Bit | Port7Bit;
    InternalMemory.OverheatTemp_write( 835 );
    //Set Standard Menu
    ReefAngel.AddStandardMenu();
    //Webserver Authentication
    ReefAngel.Network.WifiAuthentication("hnnhflns");
    //DDNS Server
    ReefAngel.DDNS("300");
    ReefAngel.StandardHeater( Port2,765,768 );
    ReefAngel.Relay.DelayedOn( Port3,10 );
    ReefAngel.DosingPumpRepeat( Port4,0,480,60 );
    ReefAngel.StandardLights( Port5,9,0,14,0 );
    ReefAngel.Relay.DelayedOn( Port6,10 );
    ReefAngel.StandardFan( Port7,808,810 );
    ReefAngel.StandardLights( Port8,0,0,8,0 );
    ReefAngel.StandardLights( Box1_Port3,14,0,22,0 );
    ReefAngel.StandardLights( Box1_Port4,11,0,23,59 );
    ReefAngel.StandardLights( Box1_Port6,23,0,0,0 );
    ReefAngel.StandardLights( Box1_Port7,23,0,1,0 );
          // *******************  Debounced ATO code. Activate ATO no more than every 30 seconds.  *******************
//if (ReefAngel.WaterLevel.GetLevel(0) < 34) LastATO=millis();    // Start a timer
//if (millis()-LastATO<30000 && millis()-LastATO>10)     // Has it been less than 30,000 ms? (30 secs)
//  ReefAngel.Relay.Off(ATO_Pump);                         // If so, make sure the topoff pump is off
//  else
    ReefAngel.WaterLevelATO( Box1_Port8,ATO_Pump,600,75,90 );                     // Otherwise, use the normal topoff routine.
    ReefAngel.DCPump.SetMode( Constant,50,10 );
          //Mix Kalkwasser
static unsigned long Kalk_Mixing = 0;
static unsigned long stopTime = 0;
static byte prevWL=0;
if (ReefAngel.WaterLevel.GetLevel(1)==100 && prevWL<100) {
  stopTime=now()+7200; // Get time one hour from now.
prevWL = ReefAngel.WaterLevel.GetLevel(1); // Store the water level
if (now() < stopTime) { ReefAngel.Relay.On(Kalkwasser); } else { ReefAngel.Relay.Off(Kalkwasser); }
  // Delay WL ATO after water change
  static time_t wcTimer=0;
  if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
      // First 10 minutes after WC disable ATO
  if (now()-wcTimer >= 0 && now()-wcTimer < 600)
    ReefAngel.WaterLevelATO(0,ATO_Pump,720,0,1);
  // Disable ATO if ATO High IsActive()
     //Beginning of Jebao Control through Actinic and Daylight ports.
    if (hour()<1 || hour()>=8)
        ReefAngel.PWM.SetActinic(20);
        ReefAngel.PWM.SetDaylight(20);
    else if (hour()>=8 && hour()<15)
      ReefAngel.PWM.SetDaylight( TidalSwellMode(30,true) ); // Tidal Swell at 40% on sync mode
      ReefAngel.PWM.SetActinic( TidalSwellMode(30,false) ); // Tidal Swell at 40% on anti-sync mode
    else if (hour()>=15 && hour()<17)
      ReefAngel.PWM.SetDaylight( ReefCrestMode(100,85,true) ); // ReefCrest at 100% + - 85 on sync mode
      ReefAngel.PWM.SetActinic( ReefCrestMode(100,85,false) ); // ReefCrest at 100% + - 85 on anti-sync mode
    else if (hour()>=17 && hour()<19)
      ReefAngel.PWM.SetDaylight( NutrientTransportMode(90,100,2000,true) ); // Nutrient Transport on sync mode
      ReefAngel.PWM.SetActinic( NutrientTransportMode(90,100,2000,false) ); // Nutrient Transport on anti-sync mode
    else if (hour()>=19 && hour()<21)
    else if (hour()>=21 && hour()<22)
      ReefAngel.PWM.SetDaylight( ElseMode(100,85,true )); // ElseMode on sync mode, 100 +/- 85%
      ReefAngel.PWM.SetActinic( ElseMode(100,85,false )); // ElseMode on sync mode, 100 +/- 85%
    else if (hour()>=22 && hour()<23)
      ReefAngel.PWM.SetDaylight( TidalSwellMode(80,true) ); // Tidal Swell at 40% on sync mode
      ReefAngel.PWM.SetActinic( TidalSwellMode(80,false) ); // Tidal Swell at 40% on anti-sync mode
    else if (hour()>=23 && hour()<1)
      ReefAngel.PWM.SetDaylight( LongPulseMode(0,20,10,true) ); // Long pulse at 20% with 10s pulse on sync mode
      ReefAngel.PWM.SetActinic( LongPulseMode(0,20,10,false) ); // Long pulse at 20% with 10s pulse on anti sync mode
    //End of Jebao Control
    ReefAngel.Portal( "hnnhflns" );
    ReefAngel.DDNS( "300" ); // Your DDNS is hnnhflns-300.myreefangel.com
    int x,y;
    // pH Expansion
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, "PHE:" );
    ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
    // Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,57, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,57, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,66,66, "WL 1:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel(1) );
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
Re: Cannot Calibrate Water Level Sensor
Posted: Sat Mar 05, 2016 5:28 pm
You shouldn't need to change anything if you are using the latest libraries v1.1.3
Posted: Sat Mar 05, 2016 7:58 pm
by hnnhflns
I am almost positive the unit is no good. It seemed to be the issue cause ming our relays to flicker uncontrollably. With it disconnected there were no issues with it plugged in the relays would randomly flicker on and off while the display would say the ports were staying constant either off or on.
We tried completely uninstalling the Reef Angel wizard the reinstalled it. Reprogrammed the code multiple times. I tried it plugged directly into three different relays also tried it in the USB expansion. It never registered any value change it always said 0 on all four water level channels. Both with the probe out of water and submerged. Even if left it for 20 mins the value never changes.
I am going to be down your way next week maybe we can meet up. I want to buy a reef Angel plus board for another controller I have.
