Heater Function behaviour changed
Posted: Fri Mar 18, 2016 9:11 pm
by sabo
I havent changed this part of my code for a long time, and suddenly my heaters are switching with T1 values. Its worked on T2 for two years but changed when I reuploaded my code because I have been having issues with my ethernet module. I just changed my controller board because I thought it may be related. I *think* it has solved my ethernet issue (this all started a while back after a big electrical storm). So I have three temp probes, T1 is house temp, T2 and T3 are in the sump.I want (and used to have) the heaters switching on T2, now whatever I set in my code, the heaters are always switching on T1. Has something changed in the libraries or something? Can someone cast an eye over my code and see what is going on for me please.
#include <WiFiAlert.h>
// Define Custome Memory Locations
#define Mem_B_SkimmerWL      100
#define Mem_B_PHDayPower     101
#define Mem_B_PHNightPower   102
#define Mem_B_PHDuration     103
#define Mem_I_ChillerPumpT   104
#define Mem_B_CPumpMax       106
#define Mem_B_CPumpMin       107
#define Return       1
#define Pwm_Exp      2
#define ATI          3
#define Modem        4
#define Jebao1_Rhs   5
#define Jebao2_Rhs   6
#define Jebao1_Lhs   7
#define Jebao2_Lhs   8
#define ATO         Box1_Port1
#define Fuge_Led    Box1_Port2
#define Heater1     Box1_Port3
#define Doser       Box1_Port4
#define Heater2     Box1_Port5
#define Skimmer     Box1_Port6
#define Swabby      Box1_Port7
#define CPump       Box1_Port8
#define MH1         Box2_Port1
#define MH2         Box2_Port2
#define Actinics    Box2_Port3
#define Day         Box2_Port4
#define Fan         Box2_Port5
#define Unused      Box2_Port6
#define Unused      Box2_Port7
#define Unused      B0x2_Port8
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.OverheatShutoffPortsE[1] = Port1Bit | Port2Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port5Bit;
    ReefAngel.Relay.On( Pwm_Exp );
    ReefAngel.Relay.On( Return );
    ReefAngel.Relay.On( ATI );
    ReefAngel.Relay.On( Doser );
    ReefAngel.Relay.On( CPump );
    ReefAngel.Relay.On( Modem );
    ReefAngel.Relay.On( Skimmer );
    ReefAngel.MHLights( MH1 );
    ReefAngel.MHLights( MH2 );
    ReefAngel.ActinicLights( Actinics );
    ReefAngel.DayLights( Day );
    ReefAngel.ActinicLights( Fuge_Led );
    ReefAngel.ActinicLights( Fan );
    ReefAngel.StandardHeater( Heater1 );
    ReefAngel.StandardHeater( Heater2 );
    ReefAngel.WaterLevelATO( ATO );
    CheckPower();
    ReefAngel.DosingPumpRepeat1(Swabby);
        ReefAngel.Relay.Off(Skimmer);
        ReefAngel.Relay.On(Skimmer);
    if (hour()>=6 && hour()<12)
         ReefAngel.PWM.SetDaylight( ReefCrestMode(InternalMemory.read(Mem_B_PHDayPower),InternalMemory.read(Mem_B_PHDuration),true) );
         ReefAngel.PWM.SetActinic( ReefCrestMode(InternalMemory.read(Mem_B_PHDayPower),InternalMemory.read(Mem_B_PHDuration),true) );
         ReefAngel.Relay.Off( Jebao1_Lhs );
         ReefAngel.Relay.Off( Jebao2_Lhs );
         ReefAngel.Relay.On( Jebao1_Rhs );
         ReefAngel.Relay.On( Jebao2_Rhs );
    else if (hour()>=12 && hour()<18)
        ReefAngel.PWM.SetChannel( 0, ReefCrestMode(InternalMemory.read(Mem_B_PHDayPower),InternalMemory.read(Mem_B_PHDuration),true) );
        ReefAngel.PWM.SetChannel( 1, ReefCrestMode(InternalMemory.read(Mem_B_PHDayPower),InternalMemory.read(Mem_B_PHDuration),true) );
        ReefAngel.Relay.Off( Jebao1_Rhs );
        ReefAngel.Relay.Off( Jebao2_Rhs );
        ReefAngel.Relay.On( Jebao1_Lhs );
        ReefAngel.Relay.On( Jebao2_Lhs );
    else if (hour()>=18 && hour()<24)
        ReefAngel.PWM.SetDaylight( ReefCrestMode(InternalMemory.read(Mem_B_PHNightPower),InternalMemory.read(Mem_B_PHDuration),true) );
        ReefAngel.PWM.SetActinic( ReefCrestMode(InternalMemory.read(Mem_B_PHNightPower),InternalMemory.read(Mem_B_PHDuration),true) );
        ReefAngel.PWM.SetChannel( 0, ReefCrestMode(InternalMemory.read(Mem_B_PHNightPower),InternalMemory.read(Mem_B_PHDuration),true) );
        ReefAngel.PWM.SetChannel( 1, ReefCrestMode(InternalMemory.read(Mem_B_PHNightPower),InternalMemory.read(Mem_B_PHDuration),true) );
    ReefAngel.Portal( "sabo","****" );
void CheckPower() {
  static boolean powerOutage=false;
  static WiFiAlert powerAlert;
  // Power Outage - turn off everything
  if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY)) // Expansion Relay NOT present
    powerOutage=true;
    powerAlert.Send("Power+outage!");
  // Power Restored - Turn things back on
  if (powerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
    LastStart=now();
    powerOutage=false;
    powerAlert.Send("Power+restored.",true);
Re: Heater Function behaviour changed
Posted: Fri Mar 18, 2016 9:13 pm
by sabo
For now I have just unplugged the house temp probe and my sump probe becomes T1, so it works, but i'm curious as to why this has changed. I'm feeling stumped!
Posted: Sat Mar 19, 2016 6:19 am
I think I changed something when using StandardHeater. Try changing it to StandardHeater2
Posted: Sat Mar 19, 2016 8:55 am
Yeah, so definitely my fault. Code has been fixed and issue/pull request created. If you want to test you can download from my github
https://github.com/lnevo/Libraries/tree/fix_temp
There's a Download Zip link on that page.
Posted: Sat Mar 19, 2016 7:15 pm
by sabo
Thanks Inevo, just edited that function and all works as expected. Cheers
Posted: Fri Apr 22, 2016 6:19 am
by Civics14
I am so glad I found this thread, I just recently changed my programming and couldn't figure out for the life of me what happened in my code that caused my heater not to work.
I'm not a programming guru, so in order to fix this, do I open the file "ReefAngel.cpp" and remove the line "StandardHeater(T1_PROBE, HeaterRelay, LowTemp, HighTemp);" and replace it with "StandardHeater(TempProbe, HeaterRelay, LowTemp, HighTemp);" ?
Posted: Fri Apr 22, 2016 6:49 am
Exactly. Sorry about that :(
Roberto can we get that patch pushed out?
Posted: Fri Apr 22, 2016 8:41 am
Yeah, I'm currently working on updating the IDE to the newest IDE version 1.6.8 and some things changed along the way that required some changes to our libraries too.
The newest IDE had a few functionalities that I thought was worth the update.
Posted: Fri Apr 22, 2016 11:10 am
Cool, like what?
Posted: Fri Apr 22, 2016 3:05 pm
I liked the line numbers and the serial monitor that keeps open.
It also has a library manager that allows for easy update of our libraries.
Posted: Fri Apr 22, 2016 3:16 pm
by Civics14
what program do i need to open .cpp files to make this change?
Posted: Fri Apr 22, 2016 5:08 pm
Textedit or notepad if on windows
