Jebao "W1" Problems
Posted: Tue Mar 29, 2016 1:03 pm
by clw143
I have 2 Jebao wp40 pumps in my tank.
I have tried and tried to get my RA to mimic "W1" mode of the jeabo controller. I have one currently set to RA control and the other set to jeabo control for testing purposes.
This is the RA simplified code I used which gives the best so far for "W1":
  ReefAngel.PWM.SetDaylight( millis()%1300<750?100:0);
  ReefAngel.PWM.SetActinic( millis()%1300>550?0:100);
This code seems to give me very random on and off times unlike the Jeabo Controller. Why does this turn out to seem so random for on and off times? Is there a different way to accomplish this?
Re: Jebao "W1" Problems
Posted: Thu Mar 31, 2016 2:38 pm
by cosmith71
That's essentially the "ShortPulseMode" function in the RA libraries. How off is it?
My best guess is that the RA Controller does a lot of things while controlling the pumps and the Jebao controller only has that one job. The time it takes to get through a loop may vary from run to run.
Posted: Thu Mar 31, 2016 10:31 pm
by clw143
It is off enough that if you watch it, you see that it is not consistent by the naked eye.
Short Pulse is PulseMinSpeed, PulseMaxSpeed, PulseDuration (ms), PulseSync.
No where does Short Pulse allow you to set a duration for off time and another duration for on time, it only allows 1 duration which will does simulate W1 mode, the two durations required for W1 will be different based on the length of the tank to give an optimal wave length.
I have to give the benefit of the doubt that RA can do it since others controllers can do it.
Can anyone else confirm W1 mode working or similar results to mine? Plenty of posts with that same sort of millis() code in for the Jebao wave makers.
Posted: Fri Apr 01, 2016 5:44 am
by cosmith71
I just tried it, with the only exception being I used RW-15's on a PWM expansion module and it worked fine. It seemed very regular to me. Maybe you can post the rest of your code?
Posted: Fri Apr 01, 2016 12:44 pm
by clw143
#include <SunLocation.h>
  ////// ------------------Place global variable code below here
byte wp40mode;
byte WPSpeed;
SunLocation sl;
  ////// ------------------Place global variable code above here
void setup(){
  // Add Standard Menu
  ReefAngel.AddStandardMenu();
  ReefAngel.FeedingModePorts = Port3Bit | Port6Bit | Port7Bit| Port8Bit;
  ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
  ReefAngel.Relay.On( Port3 ); //Mag 12 Return Pump
  ReefAngel.Relay.On( Port4 ); //Reef Octopus Skimmer
  ////// ------------------Place additional initialization code below here
  // initialize the sunrise / sunset location
  sl.Init(30.197220, -92.080637); // Latitude , Longitude values set (LA)
  sl.SetOffset(-5,0,-5,0); // rise_hour, rise_seconds, set_hour, set_seconds (LA)
  // initialize default values for Custom Variables
  ReefAngel.CustomVar[4]=100;
  ReefAngel.CustomVar[6]=130;
  ReefAngel.CustomVar[7]=75;
  ////// ------------------Place additional initialization code above here
void loop(){
  //Alkalinity Drip
   if (ReefAngel.Params.PH < 840) {
   ReefAngel.DosingPumpRepeat(Port1, 15,
         InternalMemory.DP1RepeatInterval_read(),
         InternalMemory.DP1Timer_read());
   //Calcium Drip
   ReefAngel.DosingPumpRepeat(Port2, 45,
         InternalMemory.DP2RepeatInterval_read(),
         InternalMemory.DP2Timer_read());
  //Cooling Fans
  ReefAngel.StandardFan( Port6 );
  //Ehiem 150W Heater
  //MAXI Jet 600 ATO Pump
  ReefAngel.StandardATO( Port8 );
  //Right & Left Philips Rebel ES Royal Blue and Cool White & UV & Cree XT-E Green
  ReefAngel.PWM.Channel1PWMSlope();
  //Right Daylight Cree XP-G2 R5 Cool White
  ReefAngel.PWM.Channel2PWMSlope();
  //Right Actinic Cree XT-E Royal Blue
  ReefAngel.PWM.Channel3PWMSlope(InternalMemory.ActinicOffset_read());
  //Left Daylight Cree XP-G2 R5 Cool White
  ReefAngel.PWM.Channel4PWMSlope();
  //Left Actinic Cree XT-E Royal Blue
  ReefAngel.PWM.Channel5PWMSlope(InternalMemory.ActinicOffset_read());
  ////// ------------------Place your custom code below here
  // handle updating sunrise and sunset values
  sl.CheckAndUpdate();
  //PWM Expansion Channels = 0 if Overheat or Lights off
  if ((ReefAngel.Params.Temp[T1_PROBE]>InternalMemory.OverheatTemp_read()) || (now()<sl.GetSunRise() || now()>sl.GetSunSet())) {
    ReefAngel.PWM.SetChannel (1,0);
    ReefAngel.PWM.SetChannel (2,0);
    ReefAngel.PWM.SetChannel (3,0);
    ReefAngel.PWM.SetChannel (4,0);
    ReefAngel.PWM.SetChannel (5,0);
  // moonlight are on between sunset hour and sunrise hour
  if (hour()>=sl.GetSetHour() || hour()<=sl.GetRiseHour()) ReefAngel.PWM.SetChannel (0, (map(MoonPhase(), 0,100,10,25)));
  else ReefAngel.PWM.SetChannel (0,0);
  //Start Feeding Mode at 17:00 (hour*60*60)
  if ( (now()%86400==61200) /*|| (now()%86400==39600) */) ReefAngel.FeedingModeStart();
  //Hydor Evolution 1400 Circulation Pump & LED Cooling Fan (Port5) Off Between sunrise hour and sunset hour
  if (hour()<sl.GetRiseHour() || hour()>=sl.GetSetHour())  {
    ReefAngel.Relay.Off(Port5);
  else {
    ReefAngel.Relay.On(Port5);
    //Custom Variables and Calculations for Dosing and Lighting Durations
    int DailyAlk = ((InternalMemory.DP1Timer_read() * (.75)) * (1440 / InternalMemory.DP1RepeatInterval_read()));    //Alk ml/day
    int DailyCalc = ((InternalMemory.DP2Timer_read() * (.75)) * (1440 / InternalMemory.DP2RepeatInterval_read()));   //Calc ml/day
    int S1 = (NumMins(sl.GetSetHour(), sl.GetSetMinute()));
    int S2 = (NumMins(sl.GetRiseHour(), sl.GetRiseMinute()));
    int DayMins = (S1-S2);
    int duration = map((DayMins), 615, 850, 60, 150);
    if (duration!=ReefAngel.CustomVar[3]) {
    ReefAngel.CustomVar[3]=duration;
    InternalMemory.ActinicOffset_write(duration);
    InternalMemory.PWMSlopeDuration1_write(duration);
    InternalMemory.PWMSlopeDuration2_write(duration);
    InternalMemory.PWMSlopeDuration3_write(duration);
    InternalMemory.PWMSlopeDuration4_write(duration);
    InternalMemory.PWMSlopeDuration5_write(duration);
    if (DailyAlk!=ReefAngel.CustomVar[0]) ReefAngel.CustomVar[0]=DailyAlk;
    if (DailyCalc!=ReefAngel.CustomVar[1]) ReefAngel.CustomVar[1]=DailyCalc;
    if ((DayMins/10)!=ReefAngel.CustomVar[2]) ReefAngel.CustomVar[2]=DayMins/10;
   WPSpeed = ReefAngel.CustomVar[4];
  //assignmenets are = and comparisons are ==
  if (ReefAngel.CustomVar[5] == 1){
    ReefAngel.PWM.SetDaylight( millis()%((10 * ReefAngel.CustomVar[6]))<((10 * ReefAngel.CustomVar[7]))?WPSpeed:0); //Test "W1"
    ReefAngel.PWM.SetActinic( millis()%((10 * ReefAngel.CustomVar[6]))>((10 * ReefAngel.CustomVar[6])-(10 * ReefAngel.CustomVar[7]))?0:WPSpeed); //Test "W1"
    wp40mode=11;
  }else{
  if (hour()>=sl.GetRiseHour() && hour()<12) wp40mode=6; //sunrise hour - 11:59am
    else if (hour()>=12 && hour()<17) wp40mode=7; //12pm - 4:59pm
    else if (hour()>=17 && hour()<18) wp40mode=5; //5pm - 5:59pm
    else if (hour()>=18 && hour()<24) wp40mode=3; //6pm - 11:59pm
  else wp40mode=4; //12am - sunrise hour
  if (wp40mode==10) ReefAngel.PWM.SetDaylight( WPSpeed ); //Constant Speed
  if (wp40mode==10) ReefAngel.PWM.SetActinic( WPSpeed ); //Constant Speed
  if (wp40mode==9) ReefAngel.PWM.SetActinic( GyreMode(50,(WPSpeed),3,true ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (s), PulseSync
  if (wp40mode==9) ReefAngel.PWM.SetActinic( GyreMode(50,(WPSpeed),3,false ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (s), PulseSync
  if (wp40mode==8) ReefAngel.PWM.SetDaylight( ElseMode(75,25,true) ); //Midpoint, Offset, PulseSync
  if (wp40mode==8) ReefAngel.PWM.SetActinic( ElseMode(75,25,false) ); //Midpoint, Offset, PulseSync
  if (wp40mode==7) ReefAngel.PWM.SetDaylight( millis()%1300<750?WPSpeed:0); // "W1"
  if (wp40mode==7) ReefAngel.PWM.SetActinic( millis()%1300>550?0:WPSpeed); // "W1"
  if (wp40mode==6) ReefAngel.PWM.SetDaylight( TidalSwellMode(WPSpeed,true ) ); //WaveMaxSpeed, PulseSync
  if (wp40mode==6) ReefAngel.PWM.SetActinic( TidalSwellMode(WPSpeed,false ) ); //WaveMaxSpeed, PulseSync
  if (wp40mode==5) ReefAngel.PWM.SetDaylight( NutrientTransportMode(0,WPSpeed,2000,true ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (ms), PulseSync
  if (wp40mode==5) ReefAngel.PWM.SetActinic( NutrientTransportMode(0,WPSpeed,2000,false ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (ms), PulseSync
  if (wp40mode==4) ReefAngel.PWM.SetDaylight( LongPulseMode(0,(WPSpeed-20),3,true ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (s), PulseSync
  if (wp40mode==4) ReefAngel.PWM.SetActinic( LongPulseMode(0,(WPSpeed-20),3,false ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (s), PulseSync
  if (wp40mode==3) ReefAngel.PWM.SetDaylight( ShortPulseMode(0,WPSpeed,1200,true ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (ms), PulseSync
  if (wp40mode==3) ReefAngel.PWM.SetActinic( ShortPulseMode(0,WPSpeed,1200,false ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (ms), PulseSync
  if (wp40mode==2) ReefAngel.PWM.SetDaylight( ReefCrestMode(WPSpeed,20,true ) ); //WaveSpeed, WaveOffset, PulseSync
  if (wp40mode==2) ReefAngel.PWM.SetActinic( ReefCrestMode(WPSpeed,20,false ) ); //WaveSpeed, WaveOffset, PulseSync
  if (wp40mode==1) ReefAngel.PWM.SetDaylight( SineMode(0,WPSpeed,10,true ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (ms), PulseSync
  if (wp40mode==1) ReefAngel.PWM.SetActinic( SineMode(0,WPSpeed,10,false ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (ms), PulseSync
  if (wp40mode==0) ReefAngel.PWM.SetDaylight( TideMode(WPSpeed,100,20 ) ); //WaveSpeed, minOffset, maxOffset
  if (wp40mode==0) ReefAngel.PWM.SetActinic( TideMode(WPSpeed,100,20 ) ); //WaveSpeed, minOffset, maxOffset
  //WP-40s off for water change
  if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetDaylight(0);
  if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetActinic(0);
  ////// ------------------Place your custom code above here
Posted: Sun Apr 03, 2016 10:05 am
by clw143
The only thing I can think of is all the calculations for the custom variables? Maybe I should make these occur once a day?
Posted: Sun Apr 03, 2016 11:42 am
by cosmith71
If it were me, I'd start commenting out parts until I figured out what was causing it.
I'd start with the sunrise/sunset code (lots of float calculations).
