DC Pumps Not Responding to Time Event
Posted: Fri Apr 01, 2016 9:53 am
by CaliFSU
Hi all,
I have my dual Jaebo RW-4's on a "SetMode" schedule. They will not physically change when the time event occurs. The only fix I have for now is rebooting my relay box. Any thoughts?
#include <Tide.h>
Tide tide;
// Define Relay Ports by Name
#define MoonLights         1
#define MainPump           2
#define WhiteLED           3
#define Skimmer            4
#define BlueLED            5
#define Unused             6
#define Unused             7
#define ATO_Pump           8
	ReefAngel.AddPHExpansion();  // pH Expansion Module
	ReefAngel.FeedingModePorts = Port2Bit | Port4Bit;
	ReefAngel.WaterChangePorts = Port2Bit | Port4Bit;
	ReefAngel.DCPump.FeedingSpeed = 0;
	ReefAngel.DCPump.WaterChangeSpeed = 0;
	ReefAngel.LightsOnPorts = Port1Bit | Port3Bit | Port5Bit;
	ReefAngel.OverheatShutoffPorts = Port3Bit | Port5Bit;
	InternalMemory.OverheatTemp_write(869);
	ReefAngel.Relay.On(Port2);
	ReefAngel.Relay.On(Port4);
	ReefAngel.Relay.On(Port8);
	switch (tmWday)
	case 1: //Sunday
		if (hour() >= 11 || hour() < 8) {
			ReefAngel.StandardLights(Port1, 0);
			ReefAngel.StandardLights(Port1, 20, 0, 7, 0);
			ReefAngel.StandardLights(Port3, 11, 0, 19, 0);
			ReefAngel.StandardLights(Port5, 11, 0, 19, 0);
		break;
	case 2: //Monday
		if (hour() >= 12 || hour() < 8) {
			ReefAngel.StandardLights(Port3, 12, 0, 20, 0);
			ReefAngel.StandardLights(Port5, 12, 0, 20, 0);
		break;
	case 3: //Tuesday
		break;
	case 4: //Wednesday
		break;
	case 5: //Thursday
		break;
	case 6: //Friday
		break;
	case 7: //Saturday
		ReefAngel.StandardLights(Port3, 11, 0, 20, 0);
		ReefAngel.StandardLights(Port5, 11, 0, 20, 0);
		break;
	default:
		ReefAngel.StandardLights(Port3, 0, 0, 0, 0);
		ReefAngel.StandardLights(Port5, 0, 0, 0, 0);
		break;
	//ReefAngel.DCPump.SetMode(ReefCrest, 45, 5);
	if (hour() >= 20 || hour()<7) {
		//ReefAngel.DCPump.SetMode(TideMode(15, 3, 7), 15, 10);
		ReefAngel.DCPump.SetMode(Lagoon, 20, 5);
	else if (hour() >= 7 || hour()<20)
		ReefAngel.DCPump.SetMode(ReefCrest, 45, 10);
		//ReefAngel.DCPump.SetMode(TideMode(45, 3, 10),45,10);
	ReefAngel.Portal("CaliFSU");
Re: DC Pumps Not Responding to Time Event
Posted: Fri Apr 01, 2016 1:11 pm
by cosmith71
Change this:
to this:
if (hour() >= 7 && hour()<20)
Posted: Thu Apr 07, 2016 9:46 am
by CaliFSU
Thanks Colin this helped!
