3 way solenoid valve for RA?
Posted: Sat Apr 16, 2016 6:59 am
I am trying to find a solenoid valve that I can use with my RA. I have an AWC system that pumps water from the sump out of the house through airline tubing. I am planning on putting a calcium reactor and want to use the same line out to feed the reactor (since I only have 4 airlines going through the wall and am using one for ATO, one for water out, one for water in, and the last would be return from the CaRX). I thought I could use a 3 way solenoid valve I could control with the RA (have an expansion box outside already). That way the pump could be feeding the CaRX most of the time, and 5 min a day I could divert that to a sink to do the water change.
Has anybody used solenoid valves with the RA. Any recommendations?
Thanks a lot, Lucho
Thanks a lot, Lucho
