port 8 on relay not working
Posted: Wed Apr 20, 2016 10:54 am
by Civics14
So, I took my RA off line for a few hours when I upgraded my tank. Hooked everything back up and now port 8 doesn't supply any power. Doesn't make the clicking noise when turning it on or off.
Any suggestions on how to fix this?
Re: port 8 on relay not working
Posted: Tue Apr 26, 2016 12:39 am
by ahmed
Same here with new relay box same port
Posted: Tue Apr 26, 2016 2:56 am
by cosmith71
Check the communications cable. Make sure it's connected well. Could also be a bad cable or a bad relay in the box.
Posted: Wed Apr 27, 2016 11:32 am
by Civics14
I'll check the cable again when I get home, but how do I check a bad relay in the box in case its not the cable?
Posted: Thu Apr 28, 2016 5:22 am
by cosmith71
Maybe swap it out? I think they just plug in.
Posted: Tue May 24, 2016 11:48 am
by Civics14
any idea the part? and is it as simple as opening up the relay box and popping it out and putting one back in?
Posted: Wed May 25, 2016 4:23 am
by cosmith71
IIRC, it is. Open up the box and look. :D
