Adding memory settings?
Posted: Sun Apr 24, 2016 7:54 pm
Currently I would like to add internal memory to be able to edit sync and antisync for dc pump
And I'll probably have later request's later for other plans
#include <SunLocation.h>
#include <Tide.h>
#include <WiFiAlert.h>
// Won't compile without this...
// ReefAngel.DCPump.UseMemory=true;
// Custom menus
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Feeding Mode";
prog_char menu3_label[] PROGMEM = "ATO Clear";
prog_char menu4_label[] PROGMEM = "Overheat Clear";
prog_char menu5_label[] PROGMEM = "PH Calibration";
prog_char menu6_label[] PROGMEM = "Date / Time";
menu4_label, menu5_label, menu6_label
// Define Custom Memory Locations
#define Mem_I_Latitude 108
#define Mem_I_Longitude 110
#define Mem_B_AcclRiseOffset 112
#define Mem_B_AcclSetOffset 113
#define Mem_B_AcclDay 114
#define Mem_B_LightMode 160
#define Mem_B_LightOffset 161
#define Mem_I_RiseOffset 162
#define Mem_I_SetOffset 164
#define Mem_B_AcclActinicOffset 166
#define Mem_B_AcclDaylightOffset 167
#define Mem_B_LightsOffPerc 171
#define Mem_B_PrintDebug 198
#define Mem_B_ResetMemory 199
void init_memory() {
// Initialize Custom Memory Locations
InternalMemory.write_int(Mem_I_Latitude,-21);
InternalMemory.write_int(Mem_I_Longitude,-147);
InternalMemory.write(Mem_B_AcclRiseOffset,12);
InternalMemory.write(Mem_B_AcclSetOffset,13);
InternalMemory.write(Mem_B_AcclDay,0);
InternalMemory.write(Mem_B_LightOffset,10);
InternalMemory.write(Mem_B_LightMode,1);
InternalMemory.write_int(Mem_I_RiseOffset,21);
InternalMemory.write_int(Mem_I_SetOffset,21);
InternalMemory.write(Mem_B_AcclActinicOffset,250);
InternalMemory.write(Mem_B_AcclDaylightOffset,125);
InternalMemory.write(Mem_B_LightsOffPerc,1);
InternalMemory.write(Mem_B_ResetMemory,false);
#define NUMBERS_8x16
// Define Relay Ports by Name
#define Return 1
#define Heater 2
#define WhiteLeft 3
#define BlueLeft 4
#define WhiteRight 5
#define BlueRight 6
#define Autotopoff 7
#define Skimmer 8
// Custom classes
SunLocation sun;
Tide tide;
// For Cloud and preset code
int DaylightPWMValue=0;
int ActinicPWMValue=0;
int DaylightPWMValue0=0; // For cloud code, channel 0
int DaylightPWMValue2=0; // For cloud code, chennel 2
int ActinicPWMValue1=0; // For cloud code, channel 0
int ActinicPWMValue3=0; // For cloud code, chennel 2
// Needs to be global for DrawCustomGraph()
int ScreenID=1;
// Setup on controller startup/reset
ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize Menu
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit ;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit;
ReefAngel.Relay.On( Port1 ); // Return Pump
if (InternalMemory.read(Mem_B_ResetMemory))
init_memory();
ReefAngel.Relay.DelayedOn( Port1 ); // Return Pump
ReefAngel.SingleATO(true, Port7, InternalMemory.ATOExtendedTimeout_read(), 3); // ato cycle once every 3 hour
ReefAngel.Relay.Set(Port8, ReefAngel.HighATO.IsActive()); // Skimmer no time out
ReefAngel.DCPump.ExpansionChannel[4] = Sync; // Left Jebao RW4
ReefAngel.DCPump.ExpansionChannel[5] = Sync; // Right jebao rw4
ReefAngel.StandardHeater(Heater);
// Lighting and Flow
SetSun(); // Setup Sun rise/set lighting
AcclimateLED(); // Apply acclimation dimming
LEDPresets();
CheckCloud(); // Check for cloud and lightning.
UpdateLED();
ReefAngel.Portal( "troylong45" );
ReefAngel.DDNS( "1" ); // Your DDNS is troylong45-1.myreefangel.com
void SetSun() {
// Start acclimation routine
int acclRiseOffset=InternalMemory.read(Mem_B_AcclRiseOffset)*60;
int acclSetOffset=InternalMemory.read(Mem_B_AcclSetOffset)*60;
byte acclDay=InternalMemory.read(Mem_B_AcclDay);
// See if we are acclimating corals and decrease the countdown each day
static boolean acclCounterReady=false;
if (now()%SECS_PER_DAY!=0) acclCounterReady=true;
if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) {
acclDay--;
InternalMemory.write(Mem_B_AcclDay,acclDay);
// End acclimation
// Add some customizable offsets
sun.Init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
int riseOffset=InternalMemory.read_int(Mem_I_RiseOffset);
int setOffset=InternalMemory.read_int(Mem_I_SetOffset);
sun.SetOffset(riseOffset,(acclDay*acclRiseOffset),setOffset,(-acclDay*acclSetOffset)); // Bahamas
sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
byte lightOffset=InternalMemory.read(Mem_B_LightOffset); // left right separation
byte actinicOffset=InternalMemory.ActinicOffset_read();
// Make sure light resets to zero at night.
for(int i=0;i<4;i++) { ReefAngel.PWM.SetChannel(i,0); }
switch(InternalMemory.read(Mem_B_LightMode)) {
case 0: {
// Daylights
ReefAngel.PWM.Channel0PWMSlope(lightOffset,0);
ReefAngel.PWM.Channel2PWMSlope(0,lightOffset);
// Actinics
ReefAngel.PWM.Channel1PWMSlope(actinicOffset+lightOffset,actinicOffset);
ReefAngel.PWM.Channel3PWMSlope(actinicOffset,actinicOffset+lightOffset);
break;
case 1: {
// Daylights
ReefAngel.PWM.Channel0PWMParabola(lightOffset,0);
ReefAngel.PWM.Channel2PWMParabola(0,lightOffset);
// Actinics
ReefAngel.PWM.Channel1PWMParabola(actinicOffset+lightOffset,actinicOffset);
ReefAngel.PWM.Channel3PWMParabola(actinicOffset,actinicOffset+lightOffset);
break;
case 2: {
// Daylights
ReefAngel.PWM.Channel0PWMSmoothRamp(lightOffset,0);
ReefAngel.PWM.Channel2PWMSmoothRamp(0,lightOffset);
// Actinics
ReefAngel.PWM.Channel1PWMSmoothRamp(actinicOffset+lightOffset,actinicOffset);
ReefAngel.PWM.Channel3PWMSmoothRamp(actinicOffset,actinicOffset+lightOffset);
break;
case 3: {
// Daylights
ReefAngel.PWM.Channel0PWMSigmoid(lightOffset,0);
ReefAngel.PWM.Channel2PWMSigmoid(0,lightOffset);
// Actinics
ReefAngel.PWM.Channel1PWMSigmoid(actinicOffset+lightOffset,actinicOffset);
ReefAngel.PWM.Channel3PWMSigmoid(actinicOffset,actinicOffset+lightOffset);
break;
case 4: { // Reverse the actinics in the morning
// Daylights
ReefAngel.PWM.Channel0PWMParabola(lightOffset+actinicOffset,0);
ReefAngel.PWM.Channel2PWMParabola(actinicOffset,lightOffset);
// Actinics
ReefAngel.PWM.Channel1PWMParabola(lightOffset,actinicOffset);
ReefAngel.PWM.Channel3PWMParabola(0,actinicOffset+lightOffset);
break;
void AcclimateLED() {
if (acclDay > 0) {
float acclActinicOffset=acclDay*(40.95*(((float)InternalMemory.read(Mem_B_AcclActinicOffset)/100)));
float acclDaylightOffset=acclDay*(40.95*((float)InternalMemory.read(Mem_B_AcclDaylightOffset)/100));
float endPerc;
endPerc=40.95*InternalMemory.PWMSlopeEnd1_read();
ReefAngel.PWM.SetChannelRaw(1,map(ReefAngel.PWM.GetChannelValueRaw(1),0,endPerc,0,endPerc-acclActinicOffset));
endPerc=40.95*InternalMemory.PWMSlopeEnd3_read();
ReefAngel.PWM.SetChannelRaw(3,map(ReefAngel.PWM.GetChannelValueRaw(3),0,endPerc,0,endPerc-acclActinicOffset));
endPerc=40.95*InternalMemory.PWMSlopeEnd0_read();
ReefAngel.PWM.SetChannelRaw(0,map(ReefAngel.PWM.GetChannelValueRaw(0),0,endPerc,0,endPerc-acclDaylightOffset));
endPerc=40.95*InternalMemory.PWMSlopeEnd2_read();
ReefAngel.PWM.SetChannelRaw(2,map(ReefAngel.PWM.GetChannelValueRaw(2),0,endPerc,0,endPerc-acclDaylightOffset));
#define LED_1to1 Box1_Port1
#define LED_2to1 Box1_Port2
#define LED_3to1 Box1_Port3
#define LED_4to1 Box1_Port4
#define LED_BLUE Box1_Port5
#define LED_WHITE Box1_Port6
#define LED_STORM Box1_Port8
void resetRelayBox(byte ID) {
// toggle all relays except for the one selected
for (int i=Box1_Port1;i<=Box1_Port4;i++) {
if (i!=ID) ReefAngel.Relay.Auto(i);
void LEDPresets() {
static byte lastPreset=0;
DaylightPWMValue0=ReefAngel.PWM.GetChannelValueRaw(0);
ActinicPWMValue1=ReefAngel.PWM.GetChannelValueRaw(1);
DaylightPWMValue2=ReefAngel.PWM.GetChannelValueRaw(2);
ActinicPWMValue3=ReefAngel.PWM.GetChannelValueRaw(3);
DaylightPWMValue=ReefAngel.PWM.GetDaylightValueRaw();
ActinicPWMValue=ReefAngel.PWM.GetActinicValueRaw();
if (ReefAngel.Relay.isMaskOn(LED_1to1)) {
if (lastPreset!=1) resetRelayBox(LED_1to1);
DaylightPWMValue0=90*40.95;
ActinicPWMValue1=10*40.95;
DaylightPWMValue2=90*40.95;
ActinicPWMValue3=10*40.95;
lastPreset=1;
if (ReefAngel.Relay.isMaskOff(LED_1to1)) {
if (lastPreset!=2) resetRelayBox(LED_1to1);
DaylightPWMValue0=10*40.95;
ActinicPWMValue1=90*40.95;
DaylightPWMValue2=10*40.95;
ActinicPWMValue3=90*40.95;
lastPreset=2;
if (ReefAngel.Relay.isMaskOn(LED_2to1)) {
if (lastPreset!=3) resetRelayBox(LED_2to1);
DaylightPWMValue0=60*40.95;
ActinicPWMValue1=40*40.95;
DaylightPWMValue2=60*40.95;
ActinicPWMValue3=40*40.95;
lastPreset=3;
if (ReefAngel.Relay.isMaskOff(LED_2to1)) {
if (lastPreset!=4) resetRelayBox(LED_2to1);
DaylightPWMValue0=40*40.95;
ActinicPWMValue1=60*40.95;
DaylightPWMValue2=40*40.95;
ActinicPWMValue3=60*40.95;
lastPreset=4;
if (ReefAngel.Relay.isMaskOn(LED_3to1)) {
if (lastPreset!=5) resetRelayBox(LED_3to1);
DaylightPWMValue0=75*40.95;
ActinicPWMValue1=25*40.95;
DaylightPWMValue2=75*40.95;
ActinicPWMValue3=25*40.95;
lastPreset=5;
if (ReefAngel.Relay.isMaskOff(LED_3to1)) {
if (lastPreset!=6) resetRelayBox(LED_3to1);
DaylightPWMValue0=25*40.95;
ActinicPWMValue1=75*40.95;
DaylightPWMValue2=25*40.95;
ActinicPWMValue3=75*40.95;
lastPreset=6;
if (ReefAngel.Relay.isMaskOn(LED_4to1)) {
if (lastPreset!=7) resetRelayBox(LED_4to1);
DaylightPWMValue0=80*40.95;
ActinicPWMValue1=20*40.95;
DaylightPWMValue2=80*40.95;
ActinicPWMValue3=20*40.95;
lastPreset=7;
if (ReefAngel.Relay.isMaskOff(LED_4to1)) {
if (lastPreset!=8) resetRelayBox(LED_4to1);
DaylightPWMValue0=20*40.95;
ActinicPWMValue1=80*40.95;
DaylightPWMValue2=20*40.95;
ActinicPWMValue3=80*40.95;
lastPreset=8;
if (ReefAngel.Relay.isMaskOn(LED_BLUE)) {
if (lastPreset!=9) resetRelayBox(LED_BLUE);
lastPreset=9;
if (ReefAngel.Relay.isMaskOff(LED_BLUE)) {
if (lastPreset!=10) resetRelayBox(LED_BLUE);
ActinicPWMValue1=0;
ActinicPWMValue3=0;
lastPreset=10;
if (ReefAngel.Relay.isMaskOn(LED_WHITE)) {
if (lastPreset!=11) resetRelayBox(LED_WHITE);
ActinicPWMValue1=0;
ActinicPWMValue3=0;
lastPreset=11;
if (ReefAngel.Relay.isMaskOff(LED_WHITE)) {
if (lastPreset!=12) resetRelayBox(LED_WHITE);
lastPreset=12;
// Write updated values to the channels
void UpdateLED() {
ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue0);
ReefAngel.PWM.SetChannelRaw(1,ActinicPWMValue1);
ReefAngel.PWM.SetChannelRaw(2,DaylightPWMValue2);
ReefAngel.PWM.SetChannelRaw(3,ActinicPWMValue3);
ReefAngel.PWM.SetDaylightRaw(DaylightPWMValue);
ReefAngel.PWM.SetActinicRaw(ActinicPWMValue);
byte LightsOffPerc=40.95*InternalMemory.read(Mem_B_LightsOffPerc);
if (ReefAngel.PWM.GetChannelValueRaw(0)>=LightsOffPerc) ReefAngel.Relay.On(WhiteLeft); else ReefAngel.Relay.Off(WhiteLeft);
if (ReefAngel.PWM.GetChannelValueRaw(1)>=LightsOffPerc) ReefAngel.Relay.On(BlueLeft); else ReefAngel.Relay.Off(BlueLeft);
if (ReefAngel.PWM.GetChannelValueRaw(2)>=LightsOffPerc) ReefAngel.Relay.On(WhiteRight); else ReefAngel.Relay.Off(WhiteRight);
if (ReefAngel.PWM.GetChannelValueRaw(3)>=LightsOffPerc) ReefAngel.Relay.On(BlueRight); else ReefAngel.Relay.Off(BlueRight);
// Menu Code
void MenuEntry1() {
ReefAngel.FeedingModeStart();
void MenuEntry2() {
void MenuEntry3() {
ReefAngel.ATOClear();
void MenuEntry4() {
ReefAngel.OverheatClear();
void MenuEntry5() {
ReefAngel.SetupCalibratePH();
void MenuEntry6() {
ReefAngel.SetupDateTime();
// Custom Main Screen
void DrawCustomMain() {
const int NumScreens=4;
static boolean drawGraph=true;
// Main Header
// ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 35, 2,"Troy's Reef");
ReefAngel.LCD.DrawDate(5,2);
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 128, 11);
// Param Header
DrawParams(5,14);
switch (ScreenID) {
case 0:
if (drawGraph) { ReefAngel.LCD.DrawGraph(5,40); drawGraph=false; }
break;
case 1: { DrawStatus(5,40); break; }
case 2: { DrawSunMoon(5,40); break; }
// Draw Relays
DrawRelays(12,94);
// Date+Time
// ReefAngel.LCD.DrawDate(5,122);
if (ReefAngel.Joystick.IsLeft()) {
ScreenID--; drawGraph=true;
if (ReefAngel.Joystick.IsRight()) {
ScreenID++; drawGraph=true;
if (ScreenID<0) ScreenID=NumScreens-1;
if (ScreenID>=NumScreens) ScreenID=0;
void DrawCustomGraph() {
if (ScreenID==0)
ReefAngel.LCD.DrawGraph(5, 40);
void DrawParams(int x, int y) {
char buf[16];
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+5,y,"Temp:");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+80, y, "PH:");
// Temp and PH
y+=2;
ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, x+45, y, buf);
y+=6;
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+80, y, buf, Num8x16);
y+=5;
ConvertNumToString(buf, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, x+45, y, buf);
void DrawStatus(int x, int y) {
int t=x;
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"High",Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,y,"Low",Font8x16);
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_GREEN);
} else {
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_RED);
if (ReefAngel.LowATO.IsActive()) {
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_GREEN);
} else {
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_RED);
y+=12;
// Display Acclimation timer
if (acclDay > 0) {
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Acclimation Day:"); x+=100;
ReefAngel.LCD.DrawSingleMonitor(acclDay,DefaultFGColor,x,y,1);
} else {
ReefAngel.LCD.Clear(DefaultBGColor,x,y,128,y+8);
void DrawSunMoon(int x, int y) {
char buf[16];
int t=x;
y+=2;
/// Display Sunrise / Sunset
sprintf(buf, "%02d:%02d", sun.GetRiseHour(), sun.GetRiseMinute());
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Rise:"); x+=31;
ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf);
sprintf(buf, "%02d:%02d", sun.GetSetHour(), sun.GetSetMinute()); x+=36;
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Set:"); x+=25;
y+=15; x=t;
void DrawRelays(int x, int y) {
// Draw Relays
ReefAngel.LCD.DrawOutletBox(x, y, TempRelay);
void DelayedOnModes(byte relay) {
static unsigned long startTime=now();
if ( (startTime==LastStart) && ReefAngel.HighATO.IsActive()) {
ReefAngel.Relay.On(relay);
} else {
ReefAngel.Relay.DelayedOn(relay);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 50
#define Min_Cloud_Duration 6
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 5
#define Max_Clouds_per_Day 25
// In this example, start cloud after noon
#define Start_Cloud_After NumMins(9,00)
#define End_Cloud_Before NumMins(18,00)
#define Lightning_Change_per_Cloud 50
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
// of effects or unforseen result could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
// 250 minutes (or 500 minutes) can fit in that 510 minutes window.
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
// Example: { Calm, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = { Slow };
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
if (chooseLightning)
chooseLightning=false;
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
// Send the trigger
Strike();
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
Strike();
break;
case Fast:
Strike();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=4095;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
/*ReefAngel.LCD.Clear(255,0,120,132,132);
ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
int x=0;
else x=17;
//ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
else x=35;
//ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
//ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
else x=57;
//ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
else x=75;
//ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
void Strike()
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
// Flash on
int newdata=4095;
Wire.beginTransmission(0x40); // Address of the dimming expansion module
Wire.write(0x8+(4*0)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.
Wire.write(newdata&0xff); // Send the data 8 bits at a time. This sends the LSB
Wire.write(newdata>>8); // This sends the MSB
Wire.endTransmission();
Wire.write(0x8+(4*2)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
// Flash off. Return to baseline.
newdata=ReefAngel.PWM.GetChannelValueRaw(0); // Use the channel number you're flashing here
Wire.beginTransmission(0x40); // Same as above
delay(random(30,50)); // Wait from 30 to 49 ms
wdt_reset(); // Reset watchdog timer to avoid re-boots
cstart*=60;
cend*=60;
if (n>cend) return (int) PWMStart;
