Adjust dosing pumps with app?
Posted: Mon May 30, 2016 4:04 pm
Can it be set up to adjust when and how long dosing pumps come on from the app? It's a pain to go in and reprogram them every time you want to adjust them.
https://forum.reefangel.com/
[quote]
#include <[color=#CC6600]Wire[/color].h>
#include <[color=#CC6600]OneWire[/color].h>
#include <[color=#006699]LED[/color].h>
#include <[color=#006699]Relay[/color].h>
#include <[color=#006699]Timer[/color].h>
#include <[color=#006699]Salinity[/color].h>
#include <[color=#006699]RF[/color].h>
#include <[color=#006699]IO[/color].h>
#include <[color=#006699]ORP[/color].h>
#include <[color=#006699]AI[/color].h>
#include <[color=#006699]PH[/color].h>
#include <[color=#006699]WaterLevel[/color].h>
#include <[color=#006699]Humidity[/color].h>
#include <[color=#006699]DCPump[/color].h>
#include <[color=#CC6600]ReefAngel[/color].h>
[color=#7E7E7E]////// Place global variable code below here[/color]
#define NUMBERS_8x16
[color=#CC6600]void[/color] DrawCustomMain()
[color=#7E7E7E]// the graph is drawn/updated when we exit the main menu &[/color]
[color=#7E7E7E]// when the parameters are saved[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawDate[/color](6, 112);
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color](COLOR_INDIGO, COLOR_WHITE,25,5, [color=#006699]"Jeremy's Reef"[/color]);
[color=#CC6600]pingSerial[/color]();
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
[color=#CC6600]byte[/color] TempRelay = [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayData[/color];
TempRelay &= [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayMaskOff[/color];
TempRelay |= [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayMaskOn[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawOutletBox[/color](12, 93, TempRelay);
[color=#7E7E7E]////// Place global variable code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]()
[color=#7E7E7E]// This must be the first line[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]Init[/color](); [color=#7E7E7E]//Initialize controller[/color]
[color=#7E7E7E]// Ports toggled in Feeding Mode[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]FeedingModePorts[/color] = [color=#006699]Port5Bit[/color] | [color=#006699]Port6Bit[/color] | [color=#006699]Port8Bit[/color];
[color=#7E7E7E]// Ports toggled in Water Change Mode[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]WaterChangePorts[/color] = [color=#006699]Port1Bit[/color];
[color=#7E7E7E]// Ports toggled when Lights On / Off menu entry selected[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LightsOnPorts[/color] = 0;
[color=#7E7E7E]// Ports turned off when Overheat temperature exceeded[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]OverheatShutoffPorts[/color] = [color=#006699]Port3Bit[/color] | [color=#006699]Port7Bit[/color];
[color=#7E7E7E]// Use T1 probe as temperature and overheat functions[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]TempProbe[/color] = [color=#006699]T3_PROBE[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]OverheatProbe[/color] = [color=#006699]T3_PROBE[/color];
[color=#7E7E7E]// Set the Overheat temperature setting[/color]
[color=#CC6600]InternalMemory[/color].[color=#CC6600]OverheatTemp_write[/color]( 820 );
[color=#7E7E7E]// Feeeding and Water Change mode speed[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]FeedingSpeed[/color]=0;
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]WaterChangeSpeed[/color]=0;
[color=#7E7E7E]// Ports that are always on[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port4[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port5[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port6[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port8[/color] );
[color=#7E7E7E]////// Place additional initialization code below here[/color]
[color=#7E7E7E]////// Place additional initialization code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600]loop[/color]()
[color=#CC6600]ReefAngel[/color].[color=#CC6600]DosingPumpRepeat[/color]( [color=#006699]Port1[/color],15,360,8 );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]DosingPumpRepeat[/color]( [color=#006699]Port2[/color],15,360,8 );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardATO[/color]( [color=#006699]Port3[/color],30 );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardHeater[/color]( [color=#006699]Port7[/color],770,775 );
[color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetChannel[/color]( 0, [color=#CC6600]PWMSlope[/color](8,0,20,0,5,55,180,5) );
[color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetChannel[/color]( 1, [color=#CC6600]PWMSlope[/color](8,5,20,5,5,45,180,5) );
[color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetChannel[/color]( 2, [color=#CC6600]PWMSlope[/color](8,10,20,10,5,55,180,5) );
[color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetChannel[/color]( 3, [color=#CC6600]PWMSlope[/color](8,15,20,15,5,45,180,5) );
[color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetChannel[/color]( 4, [color=#CC6600]PWMSlope[/color](8,20,20,20,5,55,180,5) );
[color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetChannel[/color]( 5, [color=#CC6600]PWMSlope[/color](8,25,20,25,5,45,180,5) );
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]DaylightChannel[/color] = [color=#006699]AntiSync[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]ActinicChannel[/color] = [color=#006699]Sync[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]ExpansionChannel[/color][0] = [color=#006699]None[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]ExpansionChannel[/color][1] = [color=#006699]None[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]ExpansionChannel[/color][2] = [color=#006699]None[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]ExpansionChannel[/color][3] = [color=#006699]None[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]ExpansionChannel[/color][4] = [color=#006699]None[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]ExpansionChannel[/color][5] = [color=#006699]None[/color];
[color=#7E7E7E]////// Place your custom code below here[/color]
[color=#CC6600]if[/color] ([color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]Mode[/color]==Custom)
[color=#CC6600]ReefAngel[/color].[color=#006699]DCPump[/color].[color=#006699]UseMemory[/color] = [color=#CC6600]true[/color];
[color=#7E7E7E]////// Place your custom code above here[/color]
[color=#7E7E7E]// This should always be the last line[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]Portal[/color]( [color=#006699]"jjdezek"[/color] );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]ShowInterface[/color]();
[color=#CC6600]void[/color] DrawParamsa([color=#CC6600]int[/color] x, [color=#CC6600]int[/color] y){
[color=#CC6600]char[/color] buf[16];
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color](DPColor,DefaultBGColor,x+70,y+10,[color=#006699]"WP40L:"[/color]);
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawSingleMonitor[/color]([color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]GetDaylightValue[/color](), DPColor, x+108, y+10,1);
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color](APColor,DefaultBGColor,x+70,y+20,[color=#006699]"WP40R:"[/color]);
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawSingleMonitor[/color]([color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]GetActinicValue[/color](),APColor, x+108, y+20,1);
[color=#CC6600]void[/color] DrawParams([color=#CC6600]int[/color] x, [color=#CC6600]int[/color] y) {
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color](COLOR_BLACK,DefaultBGColor,x+5,y,[color=#006699]"Temp:"[/color]);
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color](COLOR_BLACK,DefaultBGColor,x+80, y, [color=#006699]"PH:"[/color]);
[color=#7E7E7E]// Temp and PH[/color]
y+=10;
[color=#CC6600]ConvertNumToString[/color](buf, [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color].[color=#006699]Temp[/color][[color=#006699]T1_PROBE[/color]], 10);
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawLargeText[/color](T1TempColor, DefaultBGColor, x+5, y, buf, Num8x16);
[color=#CC6600]ConvertNumToString[/color](buf, [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color].[color=#006699]Temp[/color][[color=#006699]T2_PROBE[/color]], 10);
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawLargeText[/color](T2TempColor, DefaultBGColor, x+5, y+12, buf, Num8x16);
[color=#CC6600]ConvertNumToString[/color](buf, [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color].[color=#006699]Temp[/color][[color=#006699]T3_PROBE[/color]], 10);
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawLargeText[/color](T3TempColor, DefaultBGColor, x+40, y+12, buf, Num8x16);
[color=#CC6600]ConvertNumToString[/color](buf, [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color].[color=#006699]PH[/color], 100);
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawLargeText[/color](PHColor, DefaultBGColor, x+80, y, buf, Num8x16);
y+=5;
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color]( COLOR_DARKKHAKI,DefaultBGColor,10,18, [color=#006699]"SAL:"[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawSingleMonitor[/color]( [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color].[color=#006699]Salinity[/color],COLOR_DARKKHAKI,33,18, 10 );
[color=#CC6600]void[/color] DrawStatus([color=#CC6600]int[/color] x, [color=#CC6600]int[/color] y) {
[color=#CC6600]int[/color] t=x;
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawLargeText[/color](COLOR_INDIGO,DefaultBGColor,15,y,[color=#006699]"High"[/color],Font8x16);
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawLargeText[/color](COLOR_INDIGO,DefaultBGColor,85,y,[color=#006699]"Low"[/color],Font8x16);
[color=#CC6600]if[/color] ([color=#CC6600]ReefAngel[/color].[color=#006699]HighATO[/color].[color=#CC6600]IsActive[/color]()) {
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]FillCircle[/color](55,y+3,5,COLOR_GREEN);
} [color=#CC6600]else[/color] {
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]FillCircle[/color](55,y+3,5,COLOR_RED);
[color=#CC6600]if[/color] ([color=#CC6600]ReefAngel[/color].[color=#006699]LowATO[/color].[color=#CC6600]IsActive[/color]()) {
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]FillCircle[/color](70,y+3,5,COLOR_GREEN);
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]FillCircle[/color](70,y+3,5,COLOR_RED);
[color=#CC6600]void[/color] DrawCustomGraph()
[/quote]Code: Select all
DosingPumpRepeat1(Port1);
DosingPumpRepeat2(Port2);
Pretty muchjjdezek wrote:Ok do I just delete the numbers from the temp and ato?
