help with jeabo rw-8 staying on
Posted: Wed Jun 15, 2016 4:04 pm
I have two rw-8s one pump that will not turn off anymore since adding the wifi unit. neither when I press water change or feeding does it shut off. that was the only change. also when I unlug from the pwm port it stays running. any help would be appreciated
ReefAngel.AddWifi(); // Add Wifi
ReefAngel.FeedingModePorts = Port2Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port8Bit;
// Define labels for 2014 LCD screen
//box0
ReefAngel.CustomLabels[0]="T5HO";
ReefAngel.CustomLabels[1]="Skimmer";
ReefAngel.CustomLabels[2]="FugeLight";
ReefAngel.CustomLabels[3]="Heater";
ReefAngel.CustomLabels[4]="ScrubLight";
ReefAngel.CustomLabels[5]="Kalk_Mixer";
ReefAngel.CustomLabels[6]="Kalk_ATO";
ReefAngel.CustomLabels[7]="RO_ATO";
//lowers minimum speed for DC pump
InternalMemory.DCPumpThreshold_write(0);
//gives random sopmething to randomize against
randomSeed(now()/SECS_PER_DAY);
ReefAngel.Portal("slm222"); //wifi
ReefAngel.MHLights( Port1,12,30,14,30,5 ); //t5ho
ReefAngel.MHLights( Port2,7,0,22,0,5 ); //skimmer
ReefAngel.StandardLights( Port3,18,0,10,0 ); //fugelight
ReefAngel.StandardHeater( Port4,785,788 ); //heater
ReefAngel.StandardLights( Port5,18,0,10,0 ); //scrubber light
ReefAngel.DosingPumpRepeat( Port6,0,240,25 ); // kalk mixing every 6 hours for 25 seconds
////// Wave Pattern Code Start
//Hardcode minimum speed of DC pumps
ReefAngel.DCPump.Threshold=0;
static int rmode;
byte modes[] = { ReefCrest, NutrientTransport, TidalSwell, Lagoon, Else, ReefCrest, Else };
changeMode=false;
static unsigned long feeding;
// after feed mode Continue NTM for the 60 minutes
if (now()-feeding<1800) {
ReefAngel.DCPump.Mode=Else;
//7am to 9am - wake up from night mode
else if (hour()>=7 && hour()<9){
ReefAngel.DCPump.Duration=350;
ReefAngel.DCPump.Mode=Sine;
ReefAngel.DCPump.Speed=50;
//9am to 10am - ramp up to random
else if (hour()>=9 && hour()<10){
ReefAngel.DCPump.Mode=Lagoon;
ReefAngel.DCPump.Speed=60;
//10am to 6pm - Random
else if (hour()>=10 && hour()<18) {
ReefAngel.DCPump.Speed=70;
//6pm to 7pm - slow down from random
else if (hour()>=18 && hour()<19){
//7pm to 9pm - slow down to night mode
else if (hour()>=19 && hour()<21){
// Night mode
else {
ReefAngel.DCPump.Duration=450;
ReefAngel.DCPump.Speed=40;
////// Wave Pattern Code End
////// ATO RO and Kalk Settings
if ((hour()>18 || hour()<9) && (ReefAngel.Params.PH < 822))
ReefAngel.SingleATO( true,Port7,600,0 ); // Sump switch. Kalk schedule 6pm - 7am if pH < 8.25 If ATO/Kalk runs for 10 minutes=600 seconds, then shut off.
ReefAngel.Relay.Off(Port8);
ReefAngel.SingleATO( true,Port8,500,0 ); // Sump switch. If ATO/RoDi runs for 8.20 minutes=480 seconds, then shut off.
ReefAngel.Relay.Off(Port7);
////// End ATO RO and Kalk Settings
