Virtual Outlets
Posted: Mon Jun 27, 2016 12:41 pm
by ecam
I'm trying to create some Virtual outlets....
For example... Acclimation: when toggled it will shut off all the light ports..
but the code i have now show this
//Box 1 (Box_1 portxxx)
when i do
//VO (VO_portxxx)
it doesn't compile
Re: Virtual Outlets
Posted: Mon Jun 27, 2016 6:00 pm
Both of those are commented out and neither show the full code the define the name.
It should look something like this
#define VO_Acclimation Box1_Port1
Re: Virtual Outlets
Posted: Wed Jun 29, 2016 6:17 pm
by ecam
could use a littl more help...
i setup up box4_port1 as Water change....
so when this is off the Saltwater port (Port4) cannot be toggled on or off... when on the port can then be toggled. How would i code this,
Re: Virtual Outlets
Posted: Wed Jun 29, 2016 8:59 pm
Seeing your code would help. Look at my OverridePorts function. When I have an outlet it sets this to prevent any outlet from getting turned on inadvertently.
