More ATO help needed
Smotz
I am having constant ATO timeouts
This does not seem to be working for me: ReefAngel.WaterLevelATO(1,Topoff,15,85,95);
Translated to me, this means if waterlevel(1) hits 85% turn on turn on (Topoff) until 95% for a max of 15 seconds.
I put the below code in instead. Any thoughts? Why isn't it working?
// Main Top Off
// ReefAngel.WaterLevelATO(1,Topoff,15,85,95);
// just to be safe if the water level gets to 135 or greater, turn off the topoff.
if ( ReefAngel.WaterLevel.GetLevel(1) <=85 ) ReefAngel.Reelay.On (TopOff);
if ( ReefAngel.WaterLevel.GetLevel(1) <=95 ) ReefAngel.Reelay.Off (TopOff);
if ( ReefAngel.WaterLevel.GetLevel(1) >= 135 ) ReefAngel.Relay.Off (Override);
// End Main Top Off
// Main Top Off
// End Main Top Off
- lnevo
Re: More ATO help needed
There's a fix in dev. I haven't tested, but it's two lines if you want to just apply it to the current code. Take a look at dev branch on github. Not home so sorry for the bad instructions. Can give you more detail later, but yes having same issue.
Smotz
Ok, no problem. Thanks for the reply. I'll just use the alternate code for now.
I am moving modules from one RA to another (upgrading my tank) and am running in to a slew of issues.
Smotz
lnevo wrote:There's a fix in dev. I haven't tested, but it's two lines if you want to just apply it to the current code. Take a look at dev branch on github. Not home so sorry for the bad instructions. Can give you more detail later, but yes having same issue.
A friendly reminder for a bit more details - I am having a problem finding the fix in DEV.
Smotz
Thank you, as always!
- lnevo
I put the test code on and my controller should try and refill this evening. Will keep you posted...
re76
Just as a heads up it looks like you have a typo in there. Reelay != Relay.
Smotz
holy crap!re76 wrote:Just as a heads up it looks like you have a typo in there. Reelay != Relay.
- lnevo
Smotz
Looks good for me too. Monitoring..
Smotz
Still getting random ATO timeouts - not as often but still happening for no apparent reason.
- lnevo
Smotz
Lots of timing out. What are people doing as a band-aid?
- lnevo
I am trying to upgrade my IDE so can't upload new code for a bit.
My ATO would only time out in the first few minutes and it's timed to only work starting at 8pm. So for the first few minutes I clear the timeout.
If you're ok breaking your ato up into a timed even we can control clearing the timeout..you'll still have protection but basically we have a known starting point so we wouldn't clear outside that window.
Smotz
Think it'll be better to go this route?lnevo wrote:I am trying to upgrade my IDE so can't upload new code for a bit.
