General Code Guide
Posted: Fri Jan 20, 2012 2:30 am
by projectx
Is there a guide that lists all of the commands to code the RA manually not using the RA Gen?
I know nothing about C (or any programming language for that matter) but I am very interested in learning it.
From looking at it the way it lays out a lot of it makes sense but the LCD layout, color maps etc would be helpful.
Let me know any ideas
Re: General Code Guide
Posted: Fri Jan 20, 2012 4:32 am
by binder
If you are wanting to know the commands / functions that can be used, then your best bet is to look at a couple different things.
1. The libraries themselves. https://github.com/curtbinder/ReefAngel
Focus on the ReefAngel/ReefAngel.h and ReefAngel_NokiaLCD/ReefAngel_NokiaLCD.h
2. The CustomMainScreen manual. http://forum.reefangel.com/viewtopic.php?f=14&t=109
It lists all of the functions available for use when creating a custom main screen.
That should be enough to get you going. I would check out the CustomMainScreen manual first and then look at the libraries themselves.
Posted: Fri Jan 20, 2012 7:13 pm
by projectx
Great thanks for the tip.
If I come up with a menu I like i will post up the PDE
Posted: Fri Jan 20, 2012 7:43 pm
by binder
if you have questions, feel free to ask away and someone will help out the best they can.
Posted: Sun Jan 22, 2012 7:44 pm
by rufessor
Don't feel bad if its a bit of a struggle at first, things will sorta come together one day and then you will be able to do pretty much whatever you want, but really seriously, ask questions, everyone here is super helpful. I am still new but might even be able to help answer questions in just a little bit so join in and have fun.
