WiFI utility walkthrough complete, now what?
Posted: Sat Jan 21, 2012 5:05 pm
by Cruzer
Hello All,
I have completed the "how to set up my WiFi Attachement" walkthrough successfully. The green light is slowly blinking and seems fine. I can even see it when I go into my router although it does not have a name assosiated with it, it is showing the same IP address that was shown when I looked in the WiFi settings after using the utility. How do I test it or use it lol. My final objective is to get the iphone app to work but I would like to see if it is working properly as it is now before moving on. The last sentence in the walkthrough was that I can now use it, but how do I use it? Yes I am lost lol.
Rob,
Re: WiFI utility walkthrough complete, now what?
Posted: Sat Jan 21, 2012 5:21 pm
by Cruzer
I have tried typing in the IP of the device into the brouser like the manual says to do and I get nothing. I believe I should see a portal type web page for the controller.
Posted: Sat Jan 21, 2012 5:51 pm
by Cruzer
The following is a paste of the settings after using the utility. I believe the line that I have placed some (****) by is not right. I also took out some information that I did not think should be posted and replaced the information with (XXXX). After reading more threads it looks like my WiFi is not picking up an IP? I thought it was and have been trying the other IP addresses that are showing in the paste. What do you think?
CMD
get ip
IF=DOWN
DHCP=ON
IP=0.0.0.0:2000 ******
NM=0.0.0.0
GW=0.0.0.0
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1460
FLAGS=0x7
BACKUP=0.0.0.0
<2.21> get w
SSID=XXXX
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
Passphrase=XXXXXXXXXXX
<2.21> DHCP in 5989ms, lease=3600s
IF=UP
DHCP=ON
IP=192.168.0.14:2000
NM=255.255.255.0
GW=192.168.0.1
Listen on 2000
get u
Baudrate=57600
Flow=0x0
Mode=0x2
<2.21>
Posted: Sat Jan 21, 2012 6:09 pm
I think the ip address is 192.168.0.14
To get anything when you browse
http://192.168.0.14:2000, you need to make sure that you check mark the wifi feature when you generate your code with RAGen.
Posted: Sat Jan 21, 2012 6:37 pm
by Cruzer
I just loaded the following code from RAGen with the WiFi check box checked, still can not display anything from that address. Sorry the post is so long, do not know how to use the little boxes that you can scroll in.
// Autogenerated file by RAGen (v1.1.0.127), (01/21/2012 17:20)
// RA_012112_1720.pde
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define wifi
#define SIMPLE_MENU
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.StandardATO(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.Wavemaker1(Port4);
ReefAngel.Wavemaker2(Port5);
ReefAngel.StandardFan(Port6);
Posted: Sat Jan 21, 2012 6:48 pm
Everything seems correct.
Let's check if the RAGen has the right paths.
Go to Edit->Settings and make sure you have these paths:
Sketch: Documents\Arduino
Libraries: Documents\Arduino\libraries
Arduino: C:\Program Files\Reef Angel Controller
If they are not pointing to these folders, change it and regenerate the code again.
Posted: Sat Jan 21, 2012 6:54 pm
by Cruzer
The following are the paths, so I need to change them to exactly what you have typed?
sketch: C:\Users\Rob\Documents\Arduino
Libraries: C:\Users\Rob\Documents\RAGen-v110-static\RAGen-v110-static
Arduino folder: C:\Users\Rob\Documents\RAGen-v110-static\RAGen-v110-static
Posted: Sat Jan 21, 2012 7:01 pm
Yeap. They are wrong.
Change them to:
Libraries: C:\Users\Rob\Documents\Arduino\libraries
Arduino folder: C:\Program Files\Reef Angel Controller
Regenerate your code and upload to the controller.
Posted: Sat Jan 21, 2012 7:14 pm
by Cruzer
Okay,
Progress, I can see the Reef Angle Web Server now when I go to the address. Now I need to get the settings in the PDE right, tank is going wonky now. Thank you for your patience and help Roberto.
