Error when uploading to the controller
Posted: Mon Jan 23, 2012 8:05 pm
Hello all,
Well I had the PDE running, WiFi working. Even had the Iphone app up, then I decided to try and get a signature banner up. I read the thread that covers how to modify the PDE, made some changes, ran verify in the Audrino program to check it, then uploaded it to the board. I then diconnected the cable and plugged in the WiFi and the orange/yellow lights started flashing then would stop. The green light would come on then slowly blink. When I tried the Iphone App the yellow lights would start flashing again and the app would not work. I figured the PDE that I changed messed stuff up so I tried to upload my good PDE and now I get a Protocal Error anf will not upload. I rebooted the controller and my computer and still can not upload anything to the board. The screen on the controller flashes three times while it is trying to upload but the devices that the controller are controlling are not affected. The controller is still working as far as controlling the tank but can not upload anything to it. Here is a paste of the modified PDE that I loaded if that helps. Any ideas. Sorry that I have been spamming the board with issues, just trying to get this figured out. Was fantastic for the evening that I had everything working lol.
// Autogenerated file by RAGen (v1.1.0.127), (01/22/2012 09:53)
// RA_012212_0953.pde
#define DisplayImages
#define DateTimeSetup
#define DirectTempSensor
#define wifi
#define SIMPLE_MENU
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
// Labels for the web banner
#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "Cruzer";
prog_char probe1_label[] PROGMEM = "Temp1";
prog_char probe2_label[] PROGMEM = "Temp2";
prog_char probe3_label[] PROGMEM = "Temp3";
prog_char relay1_label[] PROGMEM = "Relay1";
prog_char relay2_label[] PROGMEM = "Relay2";
prog_char relay3_label[] PROGMEM = "Relay3";
prog_char relay4_label[] PROGMEM = "Relay4";
prog_char relay5_label[] PROGMEM = "Relay5";
prog_char relay6_label[] PROGMEM = "Relay6";
prog_char relay7_label[] PROGMEM = "Relay7";
prog_char relay8_label[] PROGMEM = "Relay8";
ReefAngel.FeedingModePorts = B10111001;
ReefAngel.WaterChangePorts = B10111001;
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port8);
ReefAngel.Timer[4].Start();
ReefAngel.WebBanner();
// Specific functions
ReefAngel.StandardATO(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.Wavemaker1(Port4);
ReefAngel.Wavemaker2(Port5);
