Android APP to check 2 profiles?
Posted: Mon Oct 17, 2016 4:32 pm
by Smotz
'Lo all
Can anyone advise if the Android APP can be used to check 2 different portal usernames? I have 2 RA's at home controlling different tanks.
I already set different local statics IP addresses, set a different port on one of the RAs, and adjusted my firewall. Everything works when I log on with either user name on the web portal. I would like to use my phone app for both though.
Any suggestions are appreciated.
Re: Android APP to check 2 profiles?
Posted: Tue Oct 18, 2016 5:59 pm
by binder
No. the android app cannot currently do this. I believe the universal app can and I believe it is also available on android as well.
Posted: Tue Oct 18, 2016 6:05 pm
What if he uses home and away profiles?
Posted: Thu Oct 20, 2016 4:51 am
by Smotz
Unfortunately, the 'Portal Username' is specified globally in settings not in each profile.
Posted: Thu Oct 20, 2016 4:52 am
by Smotz
binder wrote:No. the android app cannot currently do this. I believe the universal app can and I believe it is also available on android as well.
I have wifi security enabled so the universal app doesn't work for me.
Posted: Thu Oct 20, 2016 5:43 am
by binder
I have started working on multiple profiles but stopped last year due to my life getting busy. I don't have a time frame either.
Posted: Thu Oct 20, 2016 10:03 am
by Smotz
binder wrote:I have started working on multiple profiles but stopped last year due to my life getting busy. I don't have a time frame either.
Understood. All you do is very appreciated.
