PH measures incorrectly with ATO float switches
Posted: Tue Jan 24, 2012 7:00 pm
by steamboat
when I plug in the ato float switches, the PH meter starts to read crazy low PHs like 2 or 1.5. I disconnect the float switches and PH probe starts to work and goes back to a PH of 8ish. Any ideas?
So far I have tried to: 1. reload the code, 2. switch code from dual switches to a single low, 3. plug in only a single switch 4. plug in a single float switch to different connector on the head-end unit.
I am running latest version of dev libraries, code generated with autogen, and have WIFI enables. Thanks in advance.
Re: PH measures incorrectly with ATO float switches
Posted: Tue Jan 24, 2012 7:15 pm
Is the bare wire touching the water?
It looks like the wire from the float switch is being exposed somewhere.
Posted: Tue Jan 24, 2012 9:36 pm
by steamboat
Good idea - I'll rewire the float switches tomorrow. I currently have the wires splices covered in a rubberized plastic but they are underwater so who knows if salt water found its way to the wires.... any ideas how to make the wire connections waterproof?
Posted: Wed Jan 25, 2012 5:19 am
by Deckoz2302
Heatshrink your soldered connections - before you heat shrink , dielectric gel your solder slide the tube over connection then squirt a bead of silicon in each end of the shrink tube, wait 24 hours for silicon to dry. This will be your most viable option for submerged connections. Rinse the shrink tubing before placing in tank after shrinking to remove residue from heatsource & shrink compounds released. Don't use electrical tape, both the tape and adheasive will breakdown in your tank.
