RA Client vs Portal (PWM A/D) question
Posted: Sat Nov 12, 2016 12:55 pm
Hi,
On the RA Client PWM A is reporting 45% and PWM D is reporting steady 30%. When I look at the reefangel portal the PWM Actinic and Daylight PWM channels match. Question, the DC Pump Jebao / Tunze shows the correct mode, Tidal Swell but the speed is a constant 55% with 0 duration.
I'm wondering if I have something mixed up within my code and mixing the two rather than using one. I only noticed this today since I had to remove one of my Jebao's (it broke) and I needed to increase the flow on the remaining one to make up for it. That and I was trying to mix up patterns a bit to compensate.
Also noticed that while the portal is updated to match the client I saw at the top of the web portal (RA's) it said Connection Status: Unreachable Address. So I'm screwing something up for sure...
Edit: Fixed connection status: unreachable. Profile has address. Updated IP and Port resolved.
