Asking for an interested customer....
Can the neptune WAV pumps be configured to be ran on the RA by chance? I'd think that'd be a "no", but the optimist in me is reaching to you folks first...
Re: Asking for an interested customer....
I'm almost sure you can. They use analog signal, so you need the analog version.
Don't they also get power from the apex?
I doubt that 0-10V signal on the ethernet cable can power it.
It's not made for it. You can't run the amount of current on those thin wires.
The WAV get's connected to a 1Link module with a 1Link cable. The 1Link module gets 24VDC.
The connection to the WAV module is 4 connections so it's doing power + signal over the one wire. It's not an ethernet
https://www.neptunestore.eu/en/neptune- ... eters.html
Not sure if the 1Link module is a driver module or some kind of data/power hub. The connector has 4 wires, so could easily be DC + 0-10V, but maybe they've put some of the functionality together.
