RA portal charts does not have new data
Posted: Mon Dec 26, 2016 8:27 pm
				It appears that on my portal, the data for the relay graphs end at 4pm on DEC 23rd.   Same goes for Temp and PH.  Is there something that I have done to make it stop?
Here is my code:
			Here is my code:
//#include <Salinity.h>
//#include <RF.h>
//#include <ORP.h>
//#include <WaterLevel.h>
//#include <Humidity.h>
//#include <PAR.h>
#define Mem_B_MoonOffset      100
#define Mem_B_Vacation        101
#define Mem_B_AutoFeed        102
#define Mem_B_AutoFeedPress   103
#define Mem_B_AutoFeedRepeat  104
#define Mem_B_AutoFeedOffset  105
#define Mem_I_WCFillTime      106
byte wc_status = 0;
time_t ato_endfill;
byte ato_topping = 0;
void init_memory() {
  InternalMemory.write(Mem_B_Vacation,false);
  InternalMemory.write(Mem_B_AutoFeed,true);
  InternalMemory.write(Mem_B_AutoFeedPress,2);
  InternalMemory.write(Mem_B_AutoFeedRepeat,4);
  InternalMemory.write(Mem_B_AutoFeedOffset,3);
  InternalMemory.write_int(Mem_I_WCFillTime,1200  );  //How long topoff is allowed to run
  // Define Relay Ports by Name
#define Daylight           1
#define LEDLights          2
#define ATODrain           3
#define Feeder             4
#define Mixer              5
#define Topoff             6
#define Ferts              7
#define Filter             8
  ReefAngel.Relay.Auto(Filter);
    ato_endfill = now()+15;  //add delay to ato startup
  // Ports that default off
  ReefAngel.Relay.Off(Topoff);
  ReefAngel.Relay.Off(ATODrain);
  ReefAngel.Relay.Off(Feeder);
  ReefAngel.Relay.Off(Mixer);
ReefAngel.CustomLabels[0]="Daylight";
ReefAngel.CustomLabels[1]="LED";
ReefAngel.CustomLabels[2]="Drain";
ReefAngel.CustomLabels[3]="Feeder";
ReefAngel.CustomLabels[4]="Mixer";
ReefAngel.CustomLabels[5]="Topoff";
ReefAngel.CustomLabels[6]="Ferts";
ReefAngel.CustomLabels[7]="Filter";
ReefAngel.Relay.On(Filter);
    ReefAngel.StandardLights( LEDLights,9,0,21,0 );
    ReefAngel.StandardLights( Daylight,10,30,20,30 );
    ReefAngel.PWM.SetActinic( PWMSlope(9,0,20,0,15,100,60,15) );
    //Automation
    //RunFeeder();
      //RUN ONCE A DAY AT 7 AM FOR 40 MIN
      ReefAngel.DosingPumpRepeat(ATODrain,660,1440,2400 );
    //Water Change
      if (ReefAngel.Relay.Status(ATODrain) ){
        wc_status = 1;
      if (wc_status > 0 ){
        AutoWaterChange();
    //Keep Water topped off
    AutoTopOff();
    ReefAngel.Portal( "diverjoe" );
    ReefAngel.DDNS("75");
void AutoTopOff(){
 //run for 15 sec any time float valve is turned on and WC drain is not active
 if (ato_endfill < now() && wc_status != 1 && ato_topping){
     ReefAngel.Relay.On(Topoff);
 else{
   ato_topping = 0;
   if ( ReefAngel.HighATO.IsActive() && !ato_topping){
       ato_endfill = now() + 15;
       ato_topping = 1;
void RunFeeder() {
  boolean autoFeed;
  static time_t t;
  int press, repeat, offset;
  autoFeed=InternalMemory.read(Mem_B_AutoFeed);
  press=InternalMemory.read(Mem_B_AutoFeedPress);
  repeat=InternalMemory.read(Mem_B_AutoFeedRepeat)*SECS_PER_HOUR;
  offset=InternalMemory.read(Mem_B_AutoFeedOffset)*SECS_PER_HOUR;
  ReefAngel.Relay.Set(Feeder, autoFeed);
  if (ReefAngel.Relay.Status(Feeder)!=autoFeed) {
    autoFeed=ReefAngel.Relay.Status(Feeder);
    InternalMemory.write(Mem_B_AutoFeed, autoFeed);
    ReefAngel.Relay.Auto(Feeder);
  if (autoFeed) {
    if (((hour() > 9 && hour() < 20)) && (now()+offset)%repeat==0) {
      t=now();
  if (ReefAngel.Relay.isMaskOn(Feeder)) {
    t=now()-now()%20; // One feeding has already happened.
  // Press the button once every 20 seconds
  if (now()-t < press*20) {
    ReefAngel.Relay.Set(Feeder,now()%20==0);
  } else {
void AutoWaterChange() {
 int NowMins;
 static time_t t;
    if (wc_status == 1) {
      ReefAngel.Relay.Override(Topoff,0);
      //ReefAngel.Relay.Override(Filter,0);
      ReefAngel.Relay.Off(Filter);
      t = now();
    if(ReefAngel.LowATO.IsActive() && wc_status == 1)
      wc_status = 2;   //Enter Mix mode
      ReefAngel.Relay.Auto(ATODrain);
      ReefAngel.Relay.On(Mixer);
      ReefAngel.Relay.Auto(Topoff);
      //ReefAngel.Relay.On(Topoff);
      t = now();
    //Ferts Mode
    if ( wc_status == 2){
      if (now() - t > SECS_PER_MIN  * 6){
           wc_status = 3;   //enter Ferts mode
           ReefAngel.Relay.On(Ferts);
            t = now();
    //ferts Mode
     if ( wc_status == 3){
      if (now() - t > 15){
           ReefAngel.Relay.Off(Ferts);
           wc_status = 0;
// Disable masks for things that should not be turned on by mistake
void LockPorts() {
  ReefAngel.AddPortOverrides();
