ATO not shutting off pump
Posted: Thu Apr 13, 2017 7:49 pm
My ATO is not the expansion, its the the one that came with the RA unit. The valve goes up and down and I do hear the click when the valve is at the prescribed water level. However, the pump isn't shutting off. and then the time out trips, the red light comes on the RA unit, the pump still is running. Here is my code: is something wrong in not shutting off the relay?
Thanks for any help
Thanks for any help
ReefAngel.AddHumidityExpansion(); // Humidity Expanion Module
ReefAngel.FeedingModePorts = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.ActinicLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.SingleATOLow( Port5 );
ReefAngel.StandardFan( Port8 );
ReefAngel.Portal( "psyrob" );
ReefAngel.DDNS( "psyrob-controller1.myreefangel.com" ); // Your DDNS is psyrob-99.90.0.55.myreefangel.com
