Reef Angel and Latest Arduino similtaneous installation
Posted: Thu Apr 27, 2017 11:36 pm
by Naptalene
Hi guys, hopefully you guys can tell me how to do this.
I'm on OS_x El Capitan on a 2009 Mac Pro at home and Sierra on my work current gen Mac pro.
I run the latest Arduino for my 3d printer to load the firmware etc.
How do I install the RA and the Arduino as two "seperate" things? On my PC they instaled as two seperate things but on the Mac I was getting weird errors and on Sierra I had to install an old Java version. I tried to download the latest RA IDe version from here but if have Arduiino and RA installed the RA says it's corrupt and the Arduino stops working.
It's most likely that I'm doing something wrong. Can anyone shed some light for me?
Re: Reef Angel and Latest Arduino similtaneous installation
Posted: Fri Apr 28, 2017 3:04 am
by cosmith71
I ended up uninstalling the RA Arduino and just running the Web Wizard for RA and Arduino for my 3D printer.
Posted: Mon Jun 05, 2017 1:01 pm
by KRavEN
Here's how I do it on windows.
For everything below replace %userprofle% with your actual path like c:\users\KRavEN
1. Uninstall any IDE including RA.
2. Go to %userprofile%\AppData\Local and delete Arduino15 directory
3. Install RA IDE
4. Go to %userprofile%\AppData\Local and rename it to ArduinoRA
5. Rename directory %userprofile%\Documents\Arduino to %userprofile%\Documents\ArduinoRA
6. edit %userprofile%\AppData\Local\ArduinoRA\preferences.txt and change sketchbook.path=%userprofile%\Documents\ArduinoRA
7. edit the RA shortcut on your desktop and change the target to "c:\Program Files (x86)\Reef Angel Controller\arduino.exe" --preferences-file "%userprofile%\AppData\Local\ArduinoRA\preferences.txt"
8. Now startup RA IDE and verify the sketchbook location and also the preferences.txt location
Now you can install whatever arduino IDE you wish and it shouldn't interfere with your RA IDE. I haven't tested the library upgrade or wizards so your mileage may vary.
If you work out the steps to do the same on a mac please post the details.
Posted: Tue Oct 24, 2017 4:47 am
by Naptalene
thanks so much :)
