ReefAngel.FeedingModePorts = Port1Bit; //| Port2Bit| Port5Bit| Port8Bit;;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit| Port3Bit | Port4Bit|| Port5Bit| Port7Bit;
ReefAngel.LightsOnPorts = Port5Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit| Port3Bit | Port4Bit| Port5Bit| Port7Bit;
ReefAngel.Relay.On(Port1); // Return Pump Port 1 Port1
ReefAngel.SingleATO( true,Port2,600,0 ); // ATO Port 2
ReefAngel.StandardHeater( Port3,780,795 ); // Heater Port 3
ReefAngel.StandardHeater( Port4,780,790 ); // Heater Port 4
//ReefAngel.Relay.On( Port5 ); //Cal Rx pump Port 5
ReefAngel.Relay.Set(Port6,ReefAngel.Relay.Status(Port1)); // Skimmer Port 6
ReefAngel.Relay.On( Port7 ); //Return Port 7
ReefAngel.CO2Control(Port8,730,735); //Regulator Port 8 (PhLow,PhHigh)
//ReefAngel.StandardLights( Port5,14,0,20,0 ); //
// //ReefAngel.Relay.Set(Port5,ReefAngel.Relay.Status(Port7)); // Cal Rx pump Port 5
// ReefAngel.Relay.Set(Port1,ReefAngel.Relay.Status(Port7))
//ReefAngel.Relay.On (Port5); // Fuge Light Port 5 ---- Bsmt De-humidier
//ReefAngel.DosingPumpRepeat( Port7,0,720,14 ); //Alk 15.4 mls
//ReefAngel.DosingPumpRepeat( Port8,5,720,14 );
//for 36 mls
// ReefAngel.DosingPumpRepeat( Port7,0,240,11 ); //Alk
// ReefAngel.DosingPumpRepeat( Port8,5,240,11 );
//box 2 (Box1_Portxx) Expansion Box
//!flips the status of the port for conditional statements
