12V Water solenoid valve
Posted: Fri Sep 22, 2017 3:21 pm
New to RA here and I'd like a little advice on how to operate a 12V 3/4" water solenoid valve.
I have plumbed my tank to so that I have a (semi) permanent siphon in order to perform no bucket water changes into a deep sink in an adjacent room from my setup.
I have purchased a Reef Angel Star controller and would like to know the best (proper) way to operate the valve. I'm still searching for the current draw of these valves on Amazon, but that doesn't seem to be listed in the descriptions.
I see four options, but not sure which is correct (if any):
1. Valve wired directly to an I/O port. (I/O expansion module???)
2. I/O port wired to a relay and a separate power source to operate the valve. (I/O expansion module???)
3. Wire the valve to a port on a Power Control expansion module.
4. Wire a relay to a port on a Power Control expansion module and, as in 2, a separate power source to operate the valve.
Any advice would be greatly appreciated.
