Help with /mrx,y wifi command
Hi there
The /mrx,y wifi command returns a string with memory values in hexdecimal between x and y location.
Let's say I use /mr100,199. It returns:
<MEM>001000173B3C4B1E05010217320A0F160F0F0F0162550F0005850205100A140015000A020119050F0117012C013C000A010101010101010100010001010000000093021E0A00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF</MEM>
Despite that I already know the value is in hexdecimal, I just don't know how to go on from there. I mean.. how do I decode it? How can I separate the values from each memory (100-199)?
Can someone help?
Rafa
Can someone help?
Rafa
Re: Help with /mrx,y wifi command
if it's sending you the block of memory, you will decode the block (like you know).
you have to look at each memory location to know if it's 1 or 2 bytes for the memory.
so if locations 100 thru 125 are 1 byte, then you know you only need 1 value for those locations. then for any location that is an int memory, you need 2 values (2 bytes make an int).
in your example, you should be getting 100 values (memory locations 100 thru 199). the first value is location 100, etc.
the memory range just gives you a continuous section of memory and you have to know how to interpret it.
I need to add that the values are hex coded with a leading 0 if it's a single value. so it appears that the values are 2 values and 4 values. so 0F is 15 and 10 is 16.
so byte memory locations use 2 digits and int locations use 4 digits.
look at RA_Wifi.cpp in the libraries at the memory raw command.
Binder
Perfect... I got it. So... just for the sake of documentantion:
From 100 to 104 they are all Bytes types. From the /mr100,105 I get:
<MEM>001000173B</MEM>
Memory Address 100; Hex Value 00; Dec Value: 0
Memory Address 101; Hex Value 10; Dec Value: 16
Memory Address 102; Hex Value 00; Dec Value: 0
Memory Address 103; Hex Value 17; Dec Value: 23
Memory Address 104; Hex Value 3B; Dec Value: 59
tks binder.. it really helped
Rafa
void resetInternalMemory(){
if (InternalMemory.read(100)) {
//set reset Internal Memory to False
InternalMemory.write(100,0);
InternalMemory.write(101,16); // LIGHTS_ON_H;
InternalMemory.write(102,0); // LIGHTS_ON_M;
InternalMemory.write(103,23); // LIGHTS_OFF_H;
InternalMemory.write(104,59); // LIGHTS_OFF_M;
Rafa
glad it helped!
Binder
Using this new example:
From the /mr100,108 I get:
<MEM>001000173B850205</MEM>
Memory Address 100; Hex Value 00; Dec Value: 0; [byte]
Memory Address 101; Hex Value 10; Dec Value: 16 [byte]
Memory Address 102; Hex Value 00; Dec Value: 0 [byte]
Memory Address 103; Hex Value 17; Dec Value: 23 [byte]
Memory Address 104; Hex Value 3B; Dec Value: 59 [byte]
Memory Address 105 and 106; Hex Value 8502; Dec Value: 34050 [int] ---> WRONG?
Memory Address 107; Hex Value 05; Dec Value: 5 [byte]
Memory Address 105 and 106 returns 85 and 02 respectivally. Decoding to decimal I get 34050 instead of 645 (hard coded).
Is that right? Is it backwards? Shouldn't returns 02 and 85 that decoding returns 645?
Best Regards
Rafa
InternalMemory.write_int(105,645); //INT !!!!! PH_INFERIOR_BOUND;
InternalMemory.write(107,5); //PH_DELAY_TIME_M;
Best Regards
Rafa
let me look into it a little bit. I didn't write the memory raw function and it's been a while since I looked at it completely.
so i will look closer at the code today and then reply back.
Little Indian and big Indian notation.
Some adopt big and some adopt little.
It is different from hardware to hardware, right? There is no right or wrong... Humm let's use little indian then...
Already changed this morning. My chatBot is finish. Now I receive push notifications on my phone, and can control RA throught whatsapp similar app.
Tks Roberto
Tks Binder
Tks Roberto
Tks Binder
