Questions WRT RA*
Posted: Tue Oct 17, 2017 12:28 am
Hi,
I see that the RA* is the current model and would love to eventually migrate onto it, but have the following questions about it.
1. It would seem that you don't need any sort of Cloud or WiFi expansion. It comes with it standard. Am I correct?
2. Are the existing expansions going to change/not be compatible in any way?
3. Is there a marked difference between the RA* relay box and the older ones?
4. Will it be possible to buy just the RA* head unit to swop out the RA+ down the road?
The reason i ask is.....I have my original RA+ with wifi attachment bought new. I just got a second-hand system with expansion hubs, wifi, dimming module and salinity expansion. This is for my new build. I want to eventually combine both systems with both relay boxes and have more expansions (IO expansion in particular)
I am on a budget and it makes sense to buy any expansions slowly and eventually replace the head unit. Will I be able to buy just the RA* head unit to replace the RA+ and still use my relay's etc? Is this a valid upgrade path for the foreseeable future?
