connection issue with wifi
Re: connection issue with wifi
Doesn't make sense.
If everything is working....
Can you post the log for the wifi setup?
Opening Serial Port...
Connected to serial port COM3
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 79680 3 WiFly_GSX-2.36
< 22 1052 10 config
< 23 1052 10 user
< 24 88548 3 NO NAME
< 25 88548 3 wifly-GSX-441-r1057
< 34 83648 3 WiFly_GSX-2.45
< 79 46632 3 wps_app-GSX-131
< 80 66240 3 eap_app-GSX-101
> load user
< 81 74920 3 web_app-GSX-106
< 82 37282 0 web_config.html
< 83 512 0 link.html
< 107 Free, Boot=25, Backup=24
< <4.41>
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
< set w l 5
> set w l 5
< AOK
< <4.41>
> set w s iBall-Baton$1
< set w s iBall-Baton$1
< AOK
< <4.41>
> set w p @9224284117@9004077372@
< set w p @9224284117@9004077372@
< AOK
< <4.41>
< set w k 00000000000000000000000000
< AOK
< <4.41>
> set ftp address 198.175.253.161
< set ftp address 198.175.253.161
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
< DHCP in 5378ms, lease=604800s
< IF=UP
< DHCP=ON
< IP=192.168.1.100:2000
< NM=255.255.255.0
< GW=192.168.1.1
< Listen on 2000
> show n
< show n
< SSid=iBall-Baton 1
< Chan=9
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< DHCP=OK,renew=453600
< Boot=5439
< Time=FAIL
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< NM=255.255.255.0
< GW=192.168.1.1
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Removing connection to COM3
Found router iB-WRB300N
Port 2000 is now being forwarded to 192.168.1.100
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 22 1052 10 config
< 23 1052 10 user
> load user
< <4.41>
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
< AOK
< <4.41>
< set w l 5
> set w l 5
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
< IF=UP
< DHCP=ON
< NM=255.255.255.0
< GW=192.168.1.1
< Listen on 2000
> show n
< show n
< Chan=9
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< Boot=5439
< Time=FAIL
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< NM=255.255.255.0
< GW=192.168.1.1
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Yeap. If RA is working and wifi attachment is working, it can only be the cable.
check the attach pic for wiring diagram
still not working
getting error 13: No route to host
still not working
- Screenshot_20171202-093053.png (756.06 KiB) Viewed 7185 times
code was change 1 week before but it was working fine
how to check if controller is sending data to wifi attachment in serial monitor
Open serial monitor at 57600 baud.
Then, manke sure you have Both CR and LF.
Type "GET / HTTP " and click send.
unabe to upload code now
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 28,296 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM3 -b115200 -D -V -Uflash:w:C:\Users\MAYUR\AppData\Local\Temp\build1336863122691777432.tmp\InitialInternalMemory.cpp.hex:i
Using Port : \\.\COM3
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude done. Thank you.
Watchdog Timer
Version Menu
Simple Menu
avrdude: Recv:
got this in serial monitor
HTTP/1.1 200 OK
Server: ReefAngel
Pragma: no-cache
Access-Control-Allow-Origin: *
Access-Control-Allow-Methods: GET
Connection: close
Content-Type: text/html
Content-Length: 41
<h1>Reef Angel Controller Web Server</h1>
HTTP/1.1 200 OK
Server: ReefAngel
Pragma: no-cache
Connection: close
Content-Length: 41
That means the controller is sending data to WiFi attachment.
I'm at a loss why it is not working.
All pieces are working correctly.
finally found the issue it was wifi router got it replace with new one later found out the AP Isolation was enable 2 days before it might be the problem
how to check if its sending data to portal ?
Reef Angel wifi address: 192.168.1.100:2000
My reefangelid:
Mayur
Connection Status:
Unreachable Address
Last Update:
6/22/2015, 5:24:13 PM
Displaying data from:
Webbanner database
My reefangelid:
Mayur
Connection Status:
Unreachable Address
Last Update:
Webbanner database
reefangel client log
*****12/4/2017 1:26:48 AM*****
Message:
The communication object, System.ServiceModel.Channels.ServiceChannel, cannot be used for communication because it has been Aborted.
StackTrace:
Server stack trace:
at System.ServiceModel.Channels.CommunicationObject.ThrowIfDisposedOrNotOpen()
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at ReefAngelWCFListener.IReefAngelCallback.HandleParams(ReefAngelParams paras)
at ReefAngelWCFListener.ReefAngelListener.<>c__DisplayClass10.<SendParams>b__f(Object )
*****12/4/2017 1:27:28 AM*****
Message:
Inside WifiSend:
The underlying connection was closed: An unexpected error occurred on a receive.
StackTrace:
at System.Net.WebClient.DownloadDataInternal(Uri address, WebRequest& request)
at System.Net.WebClient.DownloadString(Uri address)
at System.Net.WebClient.DownloadString(String address)
at ReefAngelWCFListener.ReefAngelListener.WifiSend()
Message:
StackTrace:
Server stack trace:
Message:
Inside WifiSend:
StackTrace:
Still the same issue portal not getting update
Is it just portal updates?
Are you able to connect to the ip address?
Yes I can connect to ip address
192.168.1.100:2000/wifi
blue light keep flashing after update
yes
the program keep running in loop
baud rate set to 57600
ERR: ?-Cmd
<4.41>
<4.41>
<4.41>
<4.41>
<4.41>
<4.41>
<4.41> factory RESET
Set Factory Defaults
<4.41> reboot
*Reboot*CMD
AOK
<4.41> save
Storing in config
<4.41
AOK
<4.41> set option deviceid ReefAngelWifi
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
<4.41> set dns name http://www.reefangel.com
AOK
<4.41> set i h 104.36.18.155
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
<4.41> set u b 57600
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*CMD
factory RESET
<4.41> reboot
*Reboot*CMD
AOK
<4.41> save
Storing
ERR: ?-Cmd
<4.41>
<4.41>
<4.41>
<4.41>
<4.41>
<4.41>
<4.41> reboot
*Reboot*CMD
AOK
<4.41> save
Storing in config
<4.41
AOK
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
AOK
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*CMD
factory RESET
<4.41> reboot
*Reboot*CMD
AOK
<4.41> save
Storing
connected now only green light flashing
thank you finally got it working
3rd temp probe is not getting detected
