Relay box...
Posted: Mon May 23, 2011 8:42 pm
by saltwaternoob
I have had a few of the outlets on the relay box go out in the last couple days, 2, 4, 6, 7 are out checked it with a multi meter, while they were supposed to be on. Any one know if there is an easy fix/ someone else experienced this? Dont think it got wet but you never know, it had things plugged in to those outlets.
Anthony
Re: Relay box...
Posted: Mon May 23, 2011 8:59 pm
What did you have connected to them?
Did they all happen within a couple days?
Did you change your code?
Re: Relay box...
Posted: Tue May 24, 2011 8:34 am
by saltwaternoob
One was a heater, moon lights on another, and a pump/wavemaker was the last one. Noticed the heater first not sure if they were all the same day or night.
Re: Relay box...
Posted: Tue May 24, 2011 8:35 am
by saltwaternoob
No change to codes for at least a month.
Re: Relay box...
Posted: Tue May 24, 2011 3:38 pm
by Ace25
Something sounds odd.. the relays stick open, not closed, when they go bad. Have you tried unplugging the controller and plugging it back in? I would guess that was your first idea so forgive me if it seems like a silly question.
Re: Relay box...
Posted: Tue May 24, 2011 10:38 pm
by saltwaternoob
I figured it out after reading your post, I switched out the "VGA" cord the other day because the one supplied with the kit wont tighten down, any bump and it comes off.
Anyways i switched them back and it works fine now. I guess its not a normal VGA cord then.
