Dimming Kessil
Posted: Wed Mar 14, 2018 4:57 pm
I have a RA+, will the dimming ports work with the Kessil or do I need an expansion module?
https://forum.reefangel.com/
So I just need to buy the RA kessil cable? And connect it to one of the dimming ports?rimai wrote:Yes, it will as long as your dimming signal is analog
Perfect. Exactly what I needed to know. So can you control the PWM as well? So to create a sunrise/sunset type effect?rimai wrote:Yes. But it uses both channels. One controls intensity and another color
Oh ok. So the kessils can dim from the RA+ dimming ports with the RA+ kessil cable?rimai wrote:Not with PWM signal. Kessil lights actually use analog signal.
But if you do have analog signal on the dimming channels, yes, you can control it to dim the lights.
