Expansion hub causing buslock
Posted: Wed Dec 26, 2018 2:51 pm
I have an expansion hub from the early days. It worked when I put it away 5 years ago but now all I get are intermittent bus locks when I use it.
Are there any firmware or code updates I would need to do to make this expansion hub function with the star? I've tried it with and without the 5v power supply and with two different usb cables. One cable worked better than the other. They're old so I'll go get a new cable if there isn't anything that can be done firmware wise...
Thanks.
Thanks.
