How to cycle power to 4 wave pumps?
Posted: Thu Feb 28, 2019 9:29 pm
by alexr54
I have the reef angel plus controller with 2 relay expansions. Currently i am using internal memory.
I have the wave maker setup to cycle every 180 seconds. I am using standard wave pumps plugged into ports 5-6 on both relay expansions.
Right now they all turn on/off at the same time. Is there any way for me to have them cycle randomly? If not randomly then at least cycle on a set time, as long as they do not all go on/off at the same time. That kind of defeats the purpose.
Can this be done at all with internal memory?
Re: How to cycle power to 4 wave pumps?
Posted: Fri Mar 01, 2019 12:32 am
Can you post your code?
Posted: Fri Mar 01, 2019 9:11 am
by alexr54
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.DayLights( Port1 );
ReefAngel.DayLights( Port2 );
ReefAngel.MoonLights( Port3 );
ReefAngel.MoonLights( Port4 );
ReefAngel.WavemakerRandom1(Port5,60,180); // Turn Port5 on/off random cycles that lasts from 15 to 60 secs
ReefAngel.WavemakerRandom2(Port6,60,180); // Turn Port6 on/off random cycles that lasts from 15 to 60 secs
// Port 5 and 6 are not synchronized.
// They work independent of each other at random times.
ReefAngel.WaterLevelATO( Port7 );
ReefAngel.Relay.DelayedOn( Box1_Port2 );
ReefAngel.StandardHeater( Box1_Port4 );
ReefAngel.WavemakerRandom1(Box1_Port5,60,180); // Turn Port5 on/off random cycles that lasts from 15 to 60 secs
ReefAngel.WavemakerRandom2(Box1_Port6,60,180); // Turn Port6 on/off random cycles that lasts from 15 to 60 secs
ReefAngel.MoonLights( Box1_Port7 );
ReefAngel.Portal( "" );
ReefAngel.DDNS( "" ); // Your DDNS is
Posted: Fri Mar 01, 2019 11:06 am
I see 4 pumps.
Do you want just 1 on and 3 off at a time?
So, each stays on for 45 seconds with a total of 180 seconds?
Posted: Fri Mar 01, 2019 12:54 pm
by alexr54
I would really like for them to cycle. Not all turn off/on at the same time like its been doing.
Based on the comments in the code
It sounds like they should cycle at random times, or maybe i am misunderstanding it.
Right now all 4 pumps turn off/on at at exactly the same time.
Posted: Fri Mar 01, 2019 12:57 pm
Elaborate please. What is cycle for you?
Give me exactly what you want the ports to do.
Posted: Fri Mar 01, 2019 1:00 pm
by alexr54
rimai wrote:Elaborate please. What is cycle for you?
Is it possible to randomize each wave maker ports 'on' and 'off' duration? Like between 60-180 seconds?
So they will each turn on and off independently at a random time between 60-180 seconds.
I hope i am making sense. And thank you for responding.
Posted: Fri Mar 01, 2019 1:09 pm
by alexr54
I suppose i can modify these settings?
To different times and load it into the unit. It will use the times i set for each but will not turn on/off randomly within the times set?
Also will i be able to still use internal memory?
What confuses me is this:
Try this:
ReefAngel.Relay.Set(Port5,now()%180<random(60,120));
ReefAngel.Relay.Set(Port6,now()%180<random(60,120));
ReefAngel.Relay.Set(Box1_Port5,now()%180<random(60,120));
ReefAngel.Relay.Set(Box1_Port6,now()%180<random(60,120));
Posted: Fri Mar 01, 2019 1:11 pm
by alexr54
Thanks Roberto,
Will i need to disable internal memory?
Posted: Fri Mar 01, 2019 1:17 pm
no. Just erase any code that uses those ports or they will have conflicts.
Posted: Fri Mar 01, 2019 1:29 pm
by alexr54
Awesome, will try this out soon as i get home.
I'm well versed in scripting with powershell and some PHP coding.
But this is new to me. I kind of get it, but need practice.
Posted: Mon Mar 04, 2019 3:41 pm
by alexr54
The code you suggested kind of made the ports go crazy. It was power cycling every half second. I had to unplug and revert.
I simply changed each port to different times and this works fine for me. I do appreciate the help!
The wizard does not allow this.
Posted: Tue Mar 05, 2019 7:29 am
by alexr54
rimai wrote:no. Just erase any code that uses those ports or they will have conflicts.
It looks like one of my wave pump ports now does not work. It must have somehow burnt out whren attempting the code you suggested. Now 3 work fine...
Is there a way to fix/replace one port?
Posted: Tue Mar 05, 2019 1:37 pm
by alexr54
Scratch that. Looks like all ports are working, although they do have quite a loud click.
I managed to get it just right. The first 2 ports for the wave maker are working randomly, the next 2 ports in the other box are synced on/off with random timing.
Looks like it’s working good! Thanks again.
