Unexpected end of stream
PostPosted: Sat May 11, 2019 8:32 am
Wifi on my reef angel has gotten to the point I rarely even try to get it set up anymore. I know part of this is due to my internet service provider and their system updates but I had some time today and I can't get it to connect. I keep getting an end of stream error when I try to connect from the app. Suggestions? I've been a RA user for years but unfortunately it's starting to get to the pii t of becoming a fancy timer :(
PostPosted: Sat May 11, 2019 9:22 am
The new cloud wifi should take care of that as it doesn't require any connection from the app to the controller.
It uses a cloud server so you no longer need firewall setup and the data just keep streaming all the time.
PostPosted: Sat May 11, 2019 10:56 am
That's great except I already have two of the older wifi attachments...
PostPosted: Sat May 11, 2019 12:49 pm
Do you know how to get the "get e" log from the wifi attachment? Can you post?
PostPosted: Mon May 13, 2019 10:37 am
I've never done that. I'll have to find instructions
PostPosted: Mon May 13, 2019 9:17 pm
Connect the wifi attachment to USB-TTL cable and open putty or tera term.
Open a new connection to the serial port at 57600 baud
Type $$$ within a second
Then type get e and hit enter.
It should dump the settings.
PostPosted: Tue Jun 11, 2019 4:20 am
rimai wrote:Connect the wifi attachment to USB-TTL cable and open putty or tera term.
thanks. Here they are:
wifly-GSX Ver: 4.41 Build: r1057, Jan 17 2014 10:26:29 on RN-131
SSID=WiFly-GSX-58
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=192.168.0.2:2000
NM=255.255.255.0
GW=192.168.0.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=209.18.47.63
Name=www.reefangel.com
Backup=rn.microchip.com
Lease=86400
FTP=198.175.253.161:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=TG1672GF2
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=TG1672G2391F2
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
PostPosted: Tue Jun 11, 2019 6:57 am
Jun 10, 2019 9:08:57 PM
Profile: Home
Host: 192.168.0.2:2000
User ID: knapp870
IOException
java.io.IOException: unexpected end of stream on Connection{192.168.0.2:2000, proxy=DIRECT hostAddress=/192.168.0.2:2000 cipherSuite=none protocol=http/1.1}
Stack Trace:
at okhttp3.internal.d.a.a(Unknown Source:114)
at okhttp3.internal.c.b.a(Unknown Source:174)
at okhttp3.internal.c.g.a(Unknown Source:165)
at okhttp3.internal.b.a.a(Unknown Source:34)
at okhttp3.internal.c.g.a(Unknown Source:6)
at okhttp3.internal.a.a.a(Unknown Source:137)
at okhttp3.internal.c.a.a(Unknown Source:160)
at okhttp3.internal.c.j.a(Unknown Source:63)
at okhttp3.y.f(Unknown Source:114)
at okhttp3.y.a(Unknown Source:37)
at info.curtbinder.reefangel.service.a.run(Unknown Source:120)
at info.curtbinder.reefangel.service.UpdateService.a(Unknown Source:13)
at info.curtbinder.reefangel.service.UpdateService.a(Unknown Source:105)
at info.curtbinder.reefangel.service.UpdateService.onHandleIntent(Unknown Source:33)
at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:76)
at android.os.Handler.dispatchMessage(Handler.java:106)
at android.os.Looper.loop(Looper.java:193)
at android.os.HandlerThread.run(HandlerThread.java:65)
Caused by: java.io.EOFException: \n not found: limit=0 content=…
at a.n.e(Unknown Source:206)
at okhttp3.internal.d.a.f(Unknown Source:4)
at okhttp3.internal.d.a.a(Unknown Source:37)
... 23 more
PostPosted: Tue Jun 11, 2019 9:49 am
I would recommend resetting the settings.
viewtopic.php?f=3&t=4601
PostPosted: Wed Jun 19, 2019 5:19 pm
Ok I tried resetting and still getting unexpected end of stream. What's next?
Next
Return to Standard
