Relay Charts Only Working for 1-3?
Related to the Portal
PostPosted: Mon May 20, 2019 1:19 pm
I was looking into adding the relay charts to the U-App, and in doing so, I noticed that only charts for relays 1-3 appear to be working. Is this a known issue? Something specific to my configuration?
-Steve
PostPosted: Mon May 20, 2019 1:25 pm
Just a little more info. When I hit the URL, I don't see any data beyond R3.
PostPosted: Mon May 20, 2019 3:19 pm
Are you using those boxes?
If you don't use it, there is no history to show.
PostPosted: Mon May 20, 2019 3:31 pm
What constitutes "using?" Do relays need to be turning on and off, and if so, within what timeframe? Seven days?
Or do I simply need to have them configured? They are definitely showing up on the portal, and I am actively using the first four of them.
I think I need to look deeper, though. I can actually see four of the relays on the chart, but if I hit the URL, I only seem to get data back for r1, r2, and r3.
This is what I'm hitting...
Has data:
http://forum.reefangel.com/status/jsonp.aspx?id=sbidny&filter=r3&callback=?
No data:
http://forum.reefangel.com/status/jsonp.aspx?id=sbidny&filter=r4&callback=?
PostPosted: Mon May 20, 2019 3:42 pm
You need one of the relays to be on at one point in time through the last 7 days
Return to Portal
