Bus lock
PostPosted: Mon Jul 08, 2019 3:41 pm
Just got a bus lock, no new hardware, so sure what caused, but disconnected power and now working. Is there a way to disable functionality if a bus lock does occur? In my case it dumped my entire alk reservoir...would really like to avoid that again.
PostPosted: Tue Jul 09, 2019 4:47 pm
It looks like the salinity expansion/probe might have been the culprit. The salinity went from 30 to 6 instantly sometime before I noticed the bus lock. I tried cleaning the probe and unplugging the salinity expansion, still reads 6. There was a moment when I was fussing with the connection to the expansion hub that it read 30, but just for a moment.
Question is how do I tell if it's a bad salinity module or probe?
PostPosted: Tue Jul 09, 2019 10:01 pm
If you short out the BNC on the salinity module it should start reporting numbers, in which case it would probably be the probe.
PostPosted: Sat Jul 13, 2019 2:24 am
How do I do that?
PostPosted: Sat Jul 13, 2019 9:13 am
Use a paper clip
PostPosted: Sat Jul 13, 2019 2:51 pm
So if shorting out means jamming the paperclip into the hole where the salinity probe connects, then no it did not report any numbers, so assuming the module is the culprit.
I really like having salinity monitor, but a little nervous about this happening again. Can I chalk this up to a random occurrence or is does this happen more often?
PostPosted: Mon Jul 15, 2019 10:18 am
The bus lock usually will be present when you start having issues on the connectors/cables.
PostPosted: Mon Jul 15, 2019 5:15 pm
Checked with cable from expansion module, worked fine. Cable looks like USB to mini B?
PostPosted: Mon Jul 15, 2019 5:27 pm
Correct
PostPosted: Tue Jul 16, 2019 3:50 am
Excellent. Thanks.
Return to Standard
