Lighting/fan/portal not working as intended
Posted: Tue Nov 19, 2019 7:30 pm
by michaela
Hi everyone,
I am not sure if this is a code issue or problem with the RAstar unit.
I have uploaded the following code to;
- turn the T5 lights (ports 6 and 7) on between 10am and 4pm
- turn off the skimmer if the highATO switch is activated.
- turn on the fan when temp 1 is above 25.6 degrees C
These only work sometimes. It seems that whenever the unit is left alone for a few hours it basically continues to run as is. Every day the lights either don't come on or they come on and stay on indefinitely unless I tap the screen to wake the unit up.
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
    ReefAngel.Star();
    ReefAngel.AddPHExpansion();  // pH Expansion Module
    ReefAngel.FeedingModePortsE[0] = Port1Bit | Port4Bit;
    ReefAngel.FeedingModePortsE[1] = 0;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port4Bit;
    ReefAngel.WaterChangePortsE[1] = 0;
    ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPortsE[1] = 0;
    ReefAngel.LightsOnPortsE[1] = 0;
    InternalMemory.OverheatTemp_write( 275 );
    ReefAngel.Relay.Off( Box1_Port5 | Box1_Port6 | Box1_Port7 );
    ReefAngel.StandardHeater1( Box1_Port2 );
    ReefAngel.StandardFan1( Box1_Port3 );
    ReefAngel.Relay.DelayedOn( Box1_Port4 );
    ReefAngel.StandardLights( Box1_Port5,10,0,16,0 );
    ReefAngel.StandardLights( Box1_Port6,10,0,16,0 );
    ReefAngel.StandardLights( Box1_Port7,7,0,18,0 );
    ReefAngel.StandardHeater1( Box1_Port8 );
    boolean buzzer=false;
    if ( ReefAngel.isOverheat() ) buzzer=true;
    ReefAngel.Relay.Set(Box1_Port4,ReefAngel.HighATO.IsActive());
    if (ReefAngel.Params.Temp[T1_PROBE]<249) ReefAngel.Relay.On( Box1_Port2 );
    if (ReefAngel.Params.Temp[T1_PROBE]>256) ReefAngel.Relay.On( Box1_Port3 );
    if (ReefAngel.Params.Temp[T1_PROBE]>253) ReefAngel.Relay.Off( Box1_Port2 );
    if (ReefAngel.Params.Temp[T3_PROBE]<249) ReefAngel.Relay.On( Box1_Port8 );
    if (ReefAngel.Params.Temp[T3_PROBE]>253) ReefAngel.Relay.Off( Box1_Port8 );
    ReefAngel.Network.Cloud();
// RA_STRING1=U2FsdGVkX18dgbkr0enPhNXrgGcSxpffYBHcyfq7FfY=
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_PORT27=Port 27
// RA_LABEL LABEL_PORT16=LightFrag
// RA_LABEL LABEL_ACTINIC2=Actinic 2
// RA_LABEL LABEL_PORT26=Port 26
// RA_LABEL LABEL_PORT15=LightFrag
// RA_LABEL LABEL_PORT24=Port 24
// RA_LABEL LABEL_PORT28=Port 28
// RA_LABEL LABEL_PORT23=Port 23
// RA_LABEL LABEL_PORT14=Skimmer
// RA_LABEL LABEL_PORT13=Fan
// RA_LABEL LABEL_PORT18=HeatFrag
// RA_LABEL LABEL_PORT22=Port 22
// RA_LABEL LABEL_PORT11=Return
// RA_LABEL LABEL_PORT25=Port 25
// RA_LABEL LABEL_DAYLIGHT2=Daylight 2
// RA_LABEL LABEL_PORT17=LightQT
// RA_LABEL LABEL_PORT21=Port 21
// RA_LABEL LABEL_PORT12=HeatSump
RE the portal.
I was able to get the portal working by connecting the RA unit to a netgear wifi extender via ethernet cable. A few months ago this stopped and I am not sure why. I can't seem to get the portal to update (last update was 10/4/2019). Is there anything in this code that suggests that wouldn't work? Is there any other options to get this running? My IP address hasn't changed.
Any help would be greatly appreciated.
Michael.
Re: Lighting/fan/portal not working as intended
Posted: Tue Nov 19, 2019 11:54 pm
I opened up a new issue.
There was another report of the same problem.
https://github.com/reefangel/Libraries/issues/255
