Random feeding mode being triggered
Posted: Tue Feb 18, 2020 1:54 pm
by tngo
Has anyone ever had issues with random feeding mode being triggered? Any clues to what could cause this issue?
Tim
Re: Random feeding mode being triggered
Posted: Tue Feb 18, 2020 2:59 pm
Do you have anything on your code that triggers that?
Posted: Tue Feb 18, 2020 3:12 pm
by tngo
Nope, nothing in code that calls a feeding mode to start or stop. I only check whether feeding mode is active in code to allow the RF module to change the Vortech mode.
Tim
Posted: Thu Feb 27, 2020 12:45 pm
by tngo
Would you know what would trigger the feeding mode to begin? Would a buslock cause the feeding mode to trigger? I know that the light from my RF module sometimes would turn off and then on; resyncing the ecotech slaves when it comes on. The main unit doesn't send any bus lock issue so I didn't really pay attention to it. The main unit tries to clear the bus locks as they occur before sending out messages correct? I'm not sure on that as I'm not seeing the actual buslock messages. If buslocks can cause feeding modes to start randomly, then I'll go through and see if can find the module causing the buslock.
Posted: Thu Feb 27, 2020 7:17 pm
I don't think it would, but try disconnecting this RF module and see if there is any change.
Posted: Fri Feb 28, 2020 11:44 am
by tngo
Yeah, I'll test out the RF and dimming modules over the weekend.
Tim
Posted: Mon Mar 02, 2020 8:45 am
by tngo
It looks like the RF module causes the random feed starts to occur. Not sure how that happens. Going to connect it to a different port on the expansion hub to see what happens.
Tim
Posted: Mon Mar 02, 2020 2:53 pm
by tngo
Switching the RF module to a different port on the port expansion module didn't fix the issue. I can only assume that there is something wrong with the RF module. Do you still sell the RF modules Roberto?
Tim
Posted: Tue Mar 03, 2020 6:09 pm
I still owe you a cloud hub.
That should take care of this.
I'm working on it.
Posted: Wed Mar 04, 2020 9:47 am
by tngo
Okay cool. Thanks Roberto. Some reason everything's been stable with with the RF module plugged in. I only opened up the the RF module to check the board but it looked clean. The cloud hub will be really interesting to add.
Tim
Posted: Thu Apr 23, 2020 11:17 am
by tngo
Hi Roberto,
Any luck with the cloud hub progress? Really looking forward to trying it out.
Tim
Posted: Thu Apr 23, 2020 11:36 am
It has been sitting here but with this whole shelter in place, I decided it was best to wait.
Posted: Sat Apr 25, 2020 9:14 am
by tngo
Okay cool thanks. Let me know how much I owe you for it.
Tim
Posted: Mon Jun 01, 2020 3:21 pm
by tngo
Hi Roberto,
The cloud hub has pretty much solved all the issues with random reboots, random feeding mode calls, and intermittant RF module functionality. Thanks for making it! I'll still get a reboot of the head unit once in a while but nothing that would cause all the modules to stop and restart, so the tank has been much more stable and easier to monitor. Would I be able to add dimming modules and relays to other multiple cloud hubs or am I limited to what the head unit can process?
Tim
Posted: Mon Jun 01, 2020 9:41 pm
The head unit can only control one dimming module and up to 8 expansion relay boxes.
The cloud hub is just a virtual link from the head unit to the expansion modules. It doesn't do anything else.
It makes it possible to control expansion modules connected to it instead of directly to the head unit/expansion hub.
