What are you all using for powerheads?
PostPosted: Thu Mar 05, 2020 7:13 pm
What is everyone controlling for powerheads? Need a pair for the 72 build.
PostPosted: Fri Mar 06, 2020 12:08 pm
Mainly Ecotech MP40s; I have 3 in my 180G. I have tried the Jebao, but they give out in about a year. I stopped replacing them after the third one failed. Hydors will start to get erratic and either stop working or begin to spin backwards sometimes after a year or two. They are cheap but not controllable. The Ecotechs I've had to replace one wetside so far after about 4 years. Ecotechs are pricey, but they are stable.
Tim
PostPosted: Fri Mar 06, 2020 12:12 pm
tngo wrote:Mainly Ecotech MP40s; I have 3 in my 180G. I have tried the Jebao, but they give out in about a year. I stopped replacing them after the third one failed. Hydors will start to get erratic and either stop working or begin to spin backwards sometimes after a year or two. They are cheap but not controllable. The Ecotechs I've had to replace one wetside so far after about 4 years. Ecotechs are pricey, but they are stable.
Tim
My wife hates the Frankenstein monster bolts look of the ecotech, not to mention the $$$. I'd love to have 10-10 control if I can but also don't want a giant pump in the tank.rhis is only a 4 foot 72 gallon tank.
PostPosted: Fri Mar 06, 2020 5:04 pm
Have you thought about the gyre?
PostPosted: Fri Mar 06, 2020 5:06 pm
rimai wrote:Have you thought about the gyre?
Problem I have with those and I own an ice cap 3k is finding one that will go low enough
PostPosted: Sun Mar 08, 2020 6:16 pm
I have a pair of maxspect gyre xf230s running on my 75 gallon tank. I run them alternating at around 50-52%. works pretty good for me.
Sent from my Pixel 2 using Tapatalk
PostPosted: Mon Mar 09, 2020 8:07 am
binder wrote:I have a pair of maxspect gyre xf230s running on my 75 gallon tank. I run them alternating at around 50-52%. works pretty good for me.
What types of coral are you keeping? I was considering a pair of the ice cap 1ks too but thought it would be too much flow.
PostPosted: Tue Mar 10, 2020 12:48 pm
Tunze pumps. Rock solid and controllable.
Excellent tech support in the US.
-James-
PostPosted: Tue Mar 10, 2020 2:41 pm
GermanDude wrote:Tunze pumps. Rock solid and controllable.
I've considered nthst, but still seem a bit bulky looking
PostPosted: Tue Mar 10, 2020 7:15 pm
I found a set of maxspecy xf230s for cheap but still thinking too much flow, thinking I'll go with a pair of the new reef octopus octopulse 2s as they have 0 to 10 control so I can connect and control via RA.
Next
Return to Standard
