Wifi with 0.0.0.0 IP
Posted: Thu Jul 16, 2020 5:32 pm
I'm trying to configure my wifi attachment but everytime I set it on the wifi utility i get Ip 0.0.0.0:2000
I see the attachment connected to the router but I haven't been able to communicate with it.
How can i solve this?
Wifi Attachment Connected to COM9
Opening Serial Port...
Connected to serial port COM9
< CMD
< DHCP in 6718ms, lease=259200s
< IF=UP
< DHCP=ON
< IP=10.0.0.80:2000
< NM=255.255.255.0
< GW=10.0.0.1
< Listen on 2000
> factory RESET
< factory RESET
< Set Factory Defaults
> reboot
< <4.41>
< reboot
Removing connection to COM9
Factory Settings Restored
Verifying speed at 9600 baud
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 79680 3 WiFly_GSX-2.36
< 22 1052 10 config
< 23 1052 10 user
< 24 88548 3 wifly-GSX-441-r1057
< 34 83648 3 WiFly_GSX-2.45
< 78 86328 3 wifly-GSX-400
< 79 46632 3 wps_app-GSX-131
< 80 66240 3 eap_app-GSX-101
< 81 74920 3 web_app-GSX-106
< 82 37282 0 web_config.html
< 83 512 0 link.html
< 104 Free, Boot=24, Backup=78
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s ReefAngel
< set w s ReefAngel
< AOK
< <4.41>
> set w p bluetang
< set w p bluetang
< AOK
< <4.41>
< AOK
< <4.41>
< set ftp address 198.175.253.161
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
< Disconn from ReefAngel,INACTIVITY
< Auto-Assoc ReefAngel chan=3 mode=MIXED SCAN OK
< Joining ReefAngel now..
< Disconn from ReefAngel,1:9
< Disconn from ReefAngel,AUTH-ERR
> show n
< show n
< SSid=ReefAngel
< Chan=3
< Assoc=FAIL
< Rate=0, 1 Mb
< Auth=FAIL
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=1
< <4.41>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=0.0.0.0:2000
< NM=0.0.0.0
< GW=0.0.0.0
< HOST=104.36.18.155:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Found router P9
Unable to setup port forwarding. This step will have to be done manually. For more information for your specific type of router, please visit http://www.portforward.com
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 22 1052 10 config
< 23 1052 10 user
> load user
< <4.41>
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s ReefAngel
< set w s ReefAngel
< AOK
< <4.41>
> set w p bluetang
< set w p bluetang
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=ReefAngel
< Chan=3
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< IP=0.0.0.0:2000
< NM=0.0.0.0
< GW=0.0.0.0
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Found router P9
