A few thing wizard did wrong, how to code it
Posted: Sun Jul 26, 2020 6:36 am
by symon_say
Hi
I set al my codes with the web wizard, but some things are not working properly.
• UV in port 13 is suppose to be always on, and turn of if port 11 is off, but is off and tier to port 3.
• Wavemaker was set to 3600-7400 sec random in port 6, and opposite in port 16, but is turning like every 30 sec.
• Fuge light is set on timer for 10:00 PM to 12:00 AM, but is always on.
• Temp 2 is set to F when all the others are C.
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.FeedingModePorts = Port3Bit;
    ReefAngel.WaterChangePorts = Port5Bit;
    ReefAngel.WaterChangePortsE[0] = Port5Bit;
    ReefAngel.WaterChangePortsE[1] = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port5Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port7Bit;
    ReefAngel.OverheatShutoffPortsE[1] = Port1Bit;
    // Use T3 probe as temperature and overheat functions
    InternalMemory.OverheatTemp_write( 300 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.DelayedOn( Port3 );
    ReefAngel.Relay.DelayedOn( Box1_Port3 );
    ReefAngel.WaterLevelATO( Box1_Port5 );
    ReefAngel.DosingPumpRepeat1( Port5 );
    ReefAngel.Wavemaker2( Port6 );
    ReefAngel.Relay.Set( Box1_Port6, !ReefAngel.Relay.Status( Port6 ) );
    ReefAngel.StandardLights( Box1_Port7 );
    ReefAngel.StandardFan3( Port7 );
    if ( ReefAngel.Relay.Status( Port3 ) ) ReefAngel.Relay.Off( Box1_Port3 );
    ReefAngel.Portal( "symon_say" );
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_PORT8=N/A
// RA_LABEL LABEL_PORT27=N/A
// RA_LABEL LABEL_PORT2=Sump Led
// RA_LABEL LABEL_PORT16=Left Gyre
// RA_LABEL LABEL_PORT1=DCP 8000
// RA_LABEL LABEL_PORT7=Fan
// RA_LABEL LABEL_PORT26=N/A
// RA_LABEL LABEL_PORT15=ATO
// RA_LABEL LABEL_PORT28=N/A
// RA_LABEL LABEL_PORT23=N/A
// RA_LABEL LABEL_PORT13=UV
// RA_LABEL LABEL_PORT18=N/A
// RA_LABEL LABEL_PORT3=Skimmer
// RA_LABEL LABEL_PORT22=N/A
// RA_LABEL LABEL_PORT11=DCP 6500
// RA_LABEL LABEL_PORT25=N/A
// RA_LABEL LABEL_PORT12=Dosing pump
// RA_LABEL LABEL_PORT5=Sump Wave
// RA_LABEL LABEL_PORT14=Left AP700
// RA_LABEL LABEL_PORT6=Right Gyre
// RA_LABEL LABEL_PORT17=Fuge Kessil
// RA_LABEL LABEL_PORT4=Right AP700
// RA_LABEL LABEL_PORT21=N/A
// RA_LABEL LABEL_PORT24=N/A
Re: A few thing wizard did wrong, how to code it
Posted: Sun Jul 26, 2020 9:48 am
The webwizard cannot set internal memory. You have to do it manually on Uapp or Android app.... :( Sorry
Posted: Sun Jul 26, 2020 3:13 pm
by symon_say
Should i use In the code, instead of internal memory for the whole code?
Posted: Sun Jul 26, 2020 4:46 pm
You can do that or do what I said on previous post.
Posted: Thu Jul 30, 2020 2:30 pm
by symon_say
Ok, I set it in code mode, everything thing to works now except the ATO I have Water level module and set to 10-15% but is not turning off at 15%, what code should i add to turn off the port.
    ReefAngel.WaterChangePortsE[1] = 0;
    ReefAngel.OverheatShutoffPortsE[1] = Port3Bit | Port7Bit;
    ReefAngel.Relay.On( Box2_Port1 );
    ReefAngel.Relay.On( Box2_Port2 );
    ReefAngel.Relay.On( Box2_Port3 );
    ReefAngel.Relay.On( Box2_Port4 );
    ReefAngel.Relay.DelayedOn( Port3,30 );
    ReefAngel.Relay.DelayedOn( Box1_Port3,5 );
    ReefAngel.WaterLevelATO( Box1_Port5,10,15,1200 );
    ReefAngel.WaterLevelATO( Box2_Port5,10,15,1800 );
    ReefAngel.DosingPumpRepeat( Port5,0,60,300 );
    ReefAngel.WavemakerRandom( Port6,3600,7200 );
    ReefAngel.Relay.Set( Box2_Port6, !ReefAngel.Relay.Status( Port6 ) );
    ReefAngel.StandardLights( Box1_Port7,21,55,23,59 );
    ReefAngel.StandardLights( Box2_Port7,21,55,1,0 );
    ReefAngel.StandardFan( T3_PROBE,Port7,288,300 );
    if ( ReefAngel.Relay.Status( Box1_Port1 ) ) ReefAngel.Relay.Off( Box1_Port3 );
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_PORT8=Carbon
// RA_LABEL LABEL_PORT16=Left Jebao
// RA_LABEL LABEL_PORT14=Left Kessil
Posted: Fri Jul 31, 2020 5:10 pm
Use this:
    if (ReefAngel.WaterLevel.GetLevel()<10) ReefAngel.Relay.On(Box1_Port5);
    if (ReefAngel.WaterLevel.GetLevel()>15) ReefAngel.Relay.Off(Box1_Port5);
    if (ReefAngel.WaterLevel.GetLevel()<10) ReefAngel.Relay.On(Box2_Port5);
    if (ReefAngel.WaterLevel.GetLevel()>15) ReefAngel.Relay.Off(Box2_Port5);
instead of this:
Posted: Sat Aug 01, 2020 2:51 pm
by symon_say
Thanks.
Is this code correct? it's suppose to turn off a port in case another por is off:
if ( ReefAngel.Relay.Status( Port1 ) ) ReefAngel.Relay.Off( Port2 );
I ask because I set the statement in the wizard for on and off ports and both give the same syntax in condition:
    if ( ReefAngel.Relay.Status( Port1 ) ) ReefAngel.Relay.On( Port2 );
Posted: Fri Sep 04, 2020 12:35 pm
by symon_say
Right now i have my wavemakers set to turn on random from 30-60 min and set to opposite each other.
ReefAngel.WavemakerRandom( Port6,1800,3600 );
I'll like to add both pumps turning on random to, how can I code random turn on of left, right and both preferably 30-60 min?
Posted: Fri Sep 04, 2020 1:53 pm
Try this:
ReefAngel.WavemakerRandom1( Port6,1800,3600 );
ReefAngel.WavemakerRandom2( Port6,1800,3600 );
