Memory Error
Posted: Thu Nov 26, 2020 6:55 pm
Hi Guys,
RA Plus running the same code since July without issue until yesterday when I randomly noticed the heater was on when it shouldn't be (i.e. heater off temp < T3). I tried rebooting it, checking the memory settings, and even re-uploaded the code but it's ignoring the uploaded settings and continuing to act strange.
When I say ignoring, I changed the set points for the heater through the wizard but when I look at heater on and heater off temps through the android app it still has the old numbers. That in and of itself isn't a problem for me, but it's ignoring those temps, the relay stays on unless I change the setting through the app for the heater on and off to like 3...instead of 730 and 740 (i.e. 73.0 and 74.0 F)
Any ideas? Is the memory in the unit just cooked?
The code that was stable and running is below. Using the 1.1.3 Mac .dmg.
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port5Bit | Port6Bit;
// Use T3 probe as temperature and overheat functions
// Feeding and Water Change mode speed
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1 );
ReefAngel.StandardFan( Port3 );
ReefAngel.ActinicLights( Port5 );
ReefAngel.DayLights( Port6 );
ReefAngel.Relay.DelayedOn( Port8 );
ReefAngel.DCPump.LowATOChannel = None;
ReefAngel.DCPump.HighATOChannel = AntiSync;
// WP40 Night Mode
// go to mode defined by RF memory locations
if (hour()<InternalMemory.StdLightsOnHour_read() || hour()>InternalMemory.StdLightsOffHour_read())
ReefAngel.DCPump.Duration=InternalMemory.RFDuration_read();
ReefAngel.DCPump.Mode=InternalMemory.RFMode_read();
ReefAngel.DCPump.Speed=InternalMemory.RFSpeed_read();
else (ReefAngel.DCPump.UseMemory=true);
//ato moonlight control
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin, 2.55*MoonPhase());
ReefAngel.Portal( "hous0067" );
