Problem loading new code
Posted: Sat Dec 05, 2020 4:54 am
Hi everybody,
I had to stop using RA for quite a while as I had to move to a new house. So I had been without my tank for a couple of years. Now I am ready to start again, but I have lost some confidence with the controller.
I am trying to upload a new code as I have to set the LCD screen on a new controller board.
I compile the code and it seems ok. When I try to upload, however, I get an error message: "Serial port COM0 not found. Check port in Tools -> Serial port"
The fact that "Serial port" in "Tools" is grey (not active) makes me think that the USB-TTL converter cable is not recognized by the Controller.
What can be the reason? Could the cable be damaged? How can I possibly check if this is the case?
I thank you all guys for your precious help.
Marco
Marco
