Reef Angel Star Buzzer Issues
Posted: Tue May 25, 2021 11:40 am
Hello everyone, I just upgraded to the star from the plus. I have everything working great other than the buzzer keeps going off it is very faint and beeps continuously. I have deleted all buzzer code and it still doesn't change anything. I am lost. I don't have any flags or anything that would cause my buzzer to be on. Below is my code that has buzzer function in it. I also disconnected all attachments and it will still beep, but its faint.
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
ReefAngel.Star();
ReefAngel.AddORPExpansion(); // ORP Expansion Module
ReefAngel.AddLeakDetectorExpansion();
ReefAngel.WaterChangePortsE[0] = Port2Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port4Bit | Port6Bit;
// Ports turned off when Leak is detected
ReefAngel.LeakShutoffPortsE[0] = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.DelayedOn( Box1_Port2,5 );
ReefAngel.StandardLights( Box1_Port3,1,0,1,20 );
ReefAngel.StandardLights( Box1_Port6,23,0,11,0 );
ReefAngel.WaterLevelATO( Box1_Port7 );
ReefAngel.DosingPumpRepeat1( Box1_Port8);
ReefAngel.PWM.SetDaylight( PWMSlope( 11,45,21,30,20,60,240,0 ) );
ReefAngel.PWM.SetActinic( PWMSlope( 11,45,23,45,60,80,450,0 ) );
ReefAngel.DCPump.ExpansionChannel[0] = Sync;
ReefAngel.DCPump.ExpansionChannel[1] = Sync;
ReefAngel.DCPump.ExpansionChannel[2] = AntiSync;
boolean buzzer=false;
if ( ReefAngel.isATOTimeOut() ) buzzer=true;
if ( ReefAngel.isOverheat() ) buzzer=true;
if ( ReefAngel.isBusLock() ) buzzer=true;
if (ReefAngel.Params.Temp[T3_PROBE] >= 830 || ReefAngel.Params.Temp[T3_PROBE]<= 760) buzzer=true;
if (ReefAngel.WaterLevel.GetLevel()>= 85 || ReefAngel.WaterLevel.GetLevel()<= 60) buzzer=true;
if(ReefAngel.WaterLevel.GetLevel() <= 0) ReefAngel.Relay.Off( Box1_Port7 );
if ( ReefAngel.Params.Temp[ T3_PROBE ] > 830 ) ReefAngel.PWM.SetDaylight( 0 );
if ( ReefAngel.Params.Temp[ T3_PROBE ] > 830 ) ReefAngel.PWM.SetActinic( 0 );
if ( ReefAngel.isLightsOnMode() == 1 ) ReefAngel.PWM.SetDaylight( 10 );
if ( ReefAngel.isLightsOnMode() == 1 ) ReefAngel.PWM.SetActinic( 70 );
if ( ReefAngel.HighATO.IsActive() == 1 ) ReefAngel.Relay.Off( Port3 );
ReefAngel.Network.Cloud();
// RA_STRING1=U2FsdGVkX19daFKdnfsePMWCnvh9420pWLuv9n7HAOI=
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_PORT16=Ref Light
// RA_LABEL LABEL_ACTINIC2=Not Used
// RA_LABEL LABEL_PORT15=Not Specified
// RA_LABEL LABEL_PORT13=AWC
// RA_LABEL LABEL_PORT18=DOS
// RA_LABEL LABEL_PORT11=Return Pump
// RA_LABEL LABEL_DAYLIGHT2=Not Used
// RA_LABEL LABEL_PORT14=Heater Controller
// RA_LABEL LABEL_PORT17=ATO
// RA_LABEL LABEL_PORT12=Skimmer
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
