Hi All,
Can anyone give me some pointers on how to achieve the following, for reference I have the older RA+ with the RF module to control the older MP ES pumps;
I would like to either add a new submenu or rename and use the Water change menu to perform the following:
Set MP40s to Constant speed
Turn on a relay port
thanks
Andy
Adding a new menu
Re: Adding a new menu
check out the Custom Menu Generator thread. it's under the Software section and then Apps and the topic is Sticky. I can't link to it from my phone. You would have to create your own menu but can do it.
let me know if you need more help.
Here's the link to the thread.
https://forum.reefangel.com/viewtopic.php?f=8&t=1773
thanks, ill check that thread out.
