Controller issues
Posted: Sun Jun 20, 2021 7:20 am
by Memmo
Hi,
I can't do anything since 2 days, have tried to reboot controller but all i can see is this in the uapp
Any suggestion?
Re: Controller issues
Posted: Sun Jun 20, 2021 10:56 am
Did you try with a different browser?
Maybe clear the cache and see if that makes any difference.
Posted: Sun Jun 20, 2021 1:32 pm
by Memmo
rimai wrote:Did you try with a different browser?
Cleared the cache, works again!
Thank You!
Another issue i've experienced since i bought it (a couple years ago)... i plugged the 2x and the 6x power cord from an ati fixture in the first and second slot, it works for some days and suddendly the relay box stops working (goes on reset mode?) turning off skimmer, refugium lights...
Figured out that happens only with heavy power consumption (8x54 in this case)
Could it be a relays issue or is the whole box?
Thanks in advance
Posted: Sun Jun 20, 2021 1:49 pm
Not sure about that one. Does the breaker on the relay box trip?
Posted: Sun Jun 20, 2021 5:00 pm
by Memmo
I founded the breaker on "Reset", switched again but couple days later had the same issue
Sometimes it only needs a couple days, sometimes it lasts couple weeks but it turns, sooner or later, off.
Atm i only plugged the skimmer for delayed start after a power failure, a 50w LED fixture for the refugium and a LED tube fixture light that i use for the sump maintenance (it's switched on/off manually when needed)
Posted: Sat Jun 26, 2021 6:35 pm
by Ferdi
Having a similar issue.
Internal on wifi i can get my parameters but on the website it keeps on saying that connection status: unreachable address.
How do i fix it please?
Posted: Mon Jul 05, 2021 6:36 am
by binder
Ferdi wrote:Having a similar issue.
please create a separate topic for your issue.
your issue sounds like a port forwarding issue.
