Adding my own temp probe
howaboutme
Post by howaboutme »
I'm looking to add my own temp probe. I assume I can use this:
https://www.sparkfun.com/products/11050
I assume since it's DS18B20 it will work.
I'm not looking to replace the assembly I have now (will use it too) so is the 3-pin connector the standard 0.1" spacing?
I follow this while looking at the header pins:
left-> GND
middle-> Data
right-> +5VDC
Anything else I need to know?
Jack
Re: Adding my own temp probe
It should work
