Cloud Connection: Disconnected
nevets9333
Post by nevets9333 »
I had the star running without issue for a while. Two days ago I couldn't connect to the network from the uapp. I tried rebooting the controller, but it still won't connect. I also tried deleting and re entering the forum information on the uapp, but no luck. Please advise!
brennyn21
Re: Cloud Connection: Disconnected
Post by brennyn21 »
I am having the same issue, it looks like an issue with the cloud server. I messaged roberto and Let him know
Sincerely, Brennyn
Try now and let me know if the problem still persists
brennyn21
Post by brennyn21 »
The problem is fixed for me thank you!
Sincerely, Brennyn
nevets9333
For me it says that it is connected now, but won't update. When I try to turn a relay on it just times out. On my star itself it still says disconnected
nevets9333
The portal is showing current date and time under "last update". The Uapp says cloud status is connected, but the time, date, parameters and relays are not updating.
Does your controller show it is cloud connected?
nevets9333
No it says cloud connection is disconnected on the controller.
The uapp days connected, but nothing works.
Has your controller ever been connected to cloud server?
nevets9333
Yes, everything was connected and running for the past 18 months.
did you try rebooting the controller?
nevets9333
nevets9333
Yes have rebooted a couple times
nevets9333
My portal is connected
nevets9333
What other options can I try? Can I do like a factory reset on the controller?
Did you ever change the password?
nevets9333
I did when I was trying to troubleshoot after it wasn't working for a few days, but I changed it back.
That may be it.
Reset the password one more time and re-upload the code to your controller.
nevets9333
Worked, thanks!
