Uapp Version 3
Posted: Tue Jan 16, 2024 12:51 pm
by brennyn21
Since the portal has now been depreciated, I wanted to go over the changes in the Uapp for Version 3.
Version 3.0.1
Email Alerts & Labels in Uapp: All email alerts and labels have now been integrated into the Uapp for streamlined access and management.
Relay Activity Chart: The relay activity chart is now available in this version, to invoke this relay chart, go to the bottom relay tab in the Uapp, and click on the relay header name you want to see the chart for. Example Main Relay, Expansion Box 1, Expansion Box 2, etc. However, I am currently addressing an issue related to the display of the graph to improve its clarity and functionality.
Dark Mode Uapp Theme If you click on the menu bar in the top left, at the bottom of the list you will see a dark theme toggle.
Historical Data There is now 30 days of historical data for the graph functions prior it was 7 days.
Disconnect Alert In settings under email alerts, there is now a toggle to get alerted if your controller quits sending data to the server. This alert is trigged if your controller misses 2 portal calls which is 10 minutes. You will also receive an alert when your controller reconnects.
Version 3.02 Release data March 1st 2024
User Variables
- User Variables have now been added to log manual tests or keep track of maintenance.
- Calendar for maintenance and Tasks added.
Add Controller Updated
- Non cloud users will now use their forum username, and password to add a controller, no longer will you have to type in an IP or Port.
Edit Dashboard
- You can now edit the dashboard and hide parameters from the main display.
Uapp is now installable
- Now the ability to install the Uapp on Windows and android devices.
Please review the manual below to get familiar with the new features and updates
Uapp 3.0.2 Manual
Version 3.03 Release date May 6th 2024
Device Logs
- New menu page dedicated to to Alert Logs, IO Logs, and Relay Logs
HTTPS Support For non Cloud
- Non Cloud users now can use https for the uapp
Calibrations from the Uapp
- Calibrate modules and probes from the Uapp, currently only available for the Star.
Updated User Alerts
- You can now set alert interval, and update existing alerts.
Push Notifications for Alerts
- You can now choose between email and push notifications
Updated Relay Graphs
- Improved graphs for relays now by individual port
App Shortcuts
- Long press on the app, or right click for feeding mode, water change mode, lights on mode, and exit mode.
Small UI Enhancements
Uapp 3.0.3 Manual
Re: Uapp Version 3
Posted: Thu Jan 18, 2024 6:11 pm
by howaboutme
Regarding the relay graph. My headers aren't clickable....I'm using the none secure version. Could that be it?
Re: Uapp Version 3
Posted: Thu Jan 18, 2024 7:52 pm
by brennyn21
Can you try clearing the browser cache? My fault I forgot to add the main relay used on the RAPlus I apologize! It should be fixed now
Re: Uapp Version 3
Posted: Fri Jan 19, 2024 10:42 am
by howaboutme
Yes, I was able to click on the main header, in my case "Main Box". But the specific relay ports aren't clickable.
Re: Uapp Version 3
Posted: Fri Jan 19, 2024 10:50 am
by brennyn21
I still need to fix how the graph layout is just so it's easier to read, but if you click on the header of the relay box all the ports will load into the graph and then at the top you have a legend that shows each of your ports and you can click on those ports to filter if you want to show them on the graph. If yours is not working do you mind sharing a screenshot so I can see what's going on?
Re: Uapp Version 3
Posted: Fri Jan 19, 2024 12:02 pm
by howaboutme
Oh, I see now. Click on the header in the graph page. Got it!
Re: Uapp Version 3
Posted: Wed Jan 31, 2024 5:11 pm
by tngo
I'm having issues getting the Uapp 3 to update. I've entered the required information in the controller setup. On the status page it says Cloud:Connected; Last Updated:Never; Current Mode: Nominal. Anyone know how to get the Uapp to update with the latest data?
Re: Uapp Version 3
Posted: Wed Jan 31, 2024 5:16 pm
by brennyn21
Did you update your controller and cloud wifi attachment or Star if you are using that controller?
Re: Uapp Version 3
Posted: Wed Jan 31, 2024 5:22 pm
by brennyn21
I just checked, I do see your controller sending dater to the server so that is good, I don't see any mqtt connection from your controller so maybe your password was not encrypted correctly or wasn't updated correctly when uploading using the wizard
Re: Uapp Version 3
Posted: Wed Jan 31, 2024 6:22 pm
by tngo
Yeah I can get updates from the Android Uapp app, but when using the browser version I can't get any updates. How would I fix the mqtt connection?
Thanks.
Just saw the message in the inbox. Thanks. I'll try that later tonight.
Re: Uapp Version 3
Posted: Tue Jul 09, 2024 8:49 am
by Reefology
Hi,
I've seen images on this forum in the past where the Uapp displays the relay boxes horizontally as apposed to the default vertically.
How do we change the orientation?
Also, under internal memory/standard dimming in the Uapp, I only have access to channel 1 for both daylights and actinics. How do I access channel 2?
Re: Uapp Version 3
Posted: Tue Jul 09, 2024 3:49 pm
by brennyn21
I will add the horizontal view to the relay boxes in the next release of the Uapp, as for the internal memory I don't believe the 2 extra diming channels were ever added to the Uapp for the Star, I will add this to the TO DO list. Thanks for letting me know!
Re: Uapp Version 3
Posted: Tue Jul 09, 2024 6:27 pm
by Reefology
thanks Brennyn!
Re: Uapp Version 3
Posted: Mon Nov 25, 2024 11:50 pm
by CASPAR
Trying the Uapp , but it wont let me log in? is it the same username and password as the forum?
Re: Uapp Version 3
Posted: Mon Nov 25, 2024 11:54 pm
by brennyn21
Yes it is, but you won't be able to login until data is received from your controller.
Re: Uapp Version 3
Posted: Tue Nov 26, 2024 11:55 am
by CASPAR
HOW DO I SET THAT UP?
SAYS LOG IN FAILED USER NOT FOUND
Re: Uapp Version 3
Posted: Tue Nov 26, 2024 11:59 am
by brennyn21
Do you have the wifi attachment or cloud wifi attachment?
You will need to update your WIFI attachment. I sent you over instructions in a private message.
Re: Uapp Version 3
Posted: Sun Jun 01, 2025 3:40 pm
by Armetas
Uploaded new code to Wifi attachement and reuploaded code to ReefAngel Plus controller via web interface. All good.
But how to connect to Uapp? What credentials to use? or should I do something else?
Tried various combinations - gettting Load object failed
Re: Uapp Version 3
Posted: Mon Jun 02, 2025 10:17 am
by brennyn21
Hi Armetas, you should be using your forum username and password.
Can you post a screenshot of the error you are receiving?
