New Code Not Running After Upload?
Posted: Sat Feb 03, 2024 1:47 pm
I'm running into an odd problem this morning and can't figure out what I'm doing wrong. I've uploaded new code via Remote Upload from the Wizard. I've done this a dozen or more times this morning trying to get something working. After a little testing, I think my new code is not actually making it through. The RA* beeps like it received the new code but my changes do not seem to be taking effect. I finally figured this out by statically setting ReefAngel.CustomVar[5] = 35; Earlier this morning I had it set to ReefAngel.CustomVar[5] = ReefAngel.Params.Temp[4]; It's still reporting the temp in the uapp which leads me to believe it's not taking the code. Am I losing my marbles here? And I overlooking something really simple maybe:
Here's the code I just uploaded a few minutes ago. I heard the controller beep like it received the code. I'm still seeing the temp fluctuate on custom var 5.
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
// Define relay box ports
// Relay Box #1
#define ControllerLight Box1_Port1
#define Skimmer Box1_Port2
#define SumpLight Box1_Port3
#define RedSea_Doser Box1_Port4
#define ReturnPump Box1_Port5
#define Heater Box1_Port6
#define RedSea_ATO Box1_Port7
#define Sump_PowerHead Box1_Port8
// Relay Box #2 - No longer working in code
// Relay Box #3
#define PowerHead1 Box3_Port1
#define T5_Actinic Box3_Port2
#define PowerHead2 Box3_Port3
#define Kessil_A Box3_Port4
#define Kessil_B Box3_Port5
#define Kessil_C Box3_Port6
#define Kessil_D Box3_Port7
#define Fans Box3_Port8
#define skimmate_locker 3
#define CUSTOM_VARIABLES
byte DaylightOffset = InternalMemory.ActinicOffset_read();
int onTime = NumMins(InternalMemory.StdLightsOnHour_read(),InternalMemory.StdLightsOnMinute_read())+DaylightOffset;
int offTime = NumMins(InternalMemory.StdLightsOffHour_read(),InternalMemory.StdLightsOffMinute_read())-DaylightOffset;
2021-01-25 :: Testing using internal momory for lighting
void setup() {
ReefAngel.Star();
ReefAngel.AddMultiChannelWaterLevelExpansion();
ReefAngel.AddExtraTempProbes();
ReefAngel.FeedingModePortsE[0] = Port2Bit | Port5Bit;
ReefAngel.FeedingModePortsE[2] = Port1Bit | Port3Bit;
ReefAngel.WaterChangePortsE[0] = Port2Bit | Port5Bit;
ReefAngel.WaterChangePortsE[2] = Port1Bit | Port3Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port6Bit;
ReefAngel.OverheatShutoffPortsE[2] = Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port3Bit;
ReefAngel.LightsOnPortsE[2] = Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
InternalMemory.OverheatTemp_write(830);
// Box 1
ReefAngel.Relay.On(RedSea_ATO);
ReefAngel.Relay.On(RedSea_Doser);
ReefAngel.Relay.On(Sump_PowerHead);
ReefAngel.Relay.On(ReturnPump);
// Box 3
ReefAngel.Relay.On(PowerHead1);
ReefAngel.Relay.On(PowerHead2);
// I/O Module Testing
//for (int IO_channel = 0; IO_channel < 6; IO_channel++) {
// ReefAngel.CustomVar[IO_channel] = ReefAngel.IO.GetChannel(IO_channel);
ReefAngel.CustomVar[0] = InternalMemory.ActinicOffset_read();
ReefAngel.CustomVar[1] = InternalMemory.StdLightsOnHour_read();
ReefAngel.CustomVar[2] = InternalMemory.StdLightsOnMinute_read();
ReefAngel.CustomVar[3] = InternalMemory.StdLightsOffHour_read();
ReefAngel.CustomVar[4] = InternalMemory.StdLightsOffMinute_read();
void loop() {
ReefAngel.Relay.DelayedOn(Skimmer,5);
ReefAngel.StandardLights(T5_Actinic, DaylightOffset);
ReefAngel.StandardLights(Kessil_A);
ReefAngel.StandardLights(Kessil_B);
ReefAngel.StandardLights(Kessil_C, onTime/60, onTime%60, offTime/60, offTime%60);
ReefAngel.StandardLights(Kessil_D, onTime/60, onTime%60, offTime/60, offTime%60);
//ReefAngel.DosingPumpRepeat1(CalDoser);
//ReefAngel.DosingPumpRepeat2(AlkDoser);
//ReefAngel.DosingPumpRepeat3(MagDoser);
ReefAngel.StandardFan(Fans);
if (!daylightsOn()) { // Night mode
ReefAngel.PWM.SetDaylight2(MoonPhase()/2);
ReefAngel.PWM.SetActinic2(MoonPhase()/2);
} else {
ReefAngel.PWM.SetDaylight2(10);
ReefAngel.PWM.SetActinic2(10);
if (ReefAngel.DisplayedMenu != FEEDING_MODE || ReefAngel.DisplayedMenu != WATERCHANGE_MODE) {
if (!daylightsOn()) { // Night mode - lower the flow
ReefAngel.DCPump.SetMode(ReefCrest,45,10);
//if (now()%SECS_PER_HOUR<10*SECS _PER_MINUTE) { //put ato code here } else { // put relay off here }
//else if (now()%(2*SECS_PER_HOUR)<(5*60*1000)) { // Run NutrientTransport mode every two hours for 5 minutes
// ReefAngel.DCPump.UseMemory = false;
// ReefAngel.DCPump.SetMode(NutrientTransport,90,30);
else {
boolean buzzer=false;
if (ReefAngel.isOverheat()) buzzer=true;
if (ReefAngel.isBusLock()) buzzer=true;
if (buzzer) ReefAngel.BuzzerOn(2); else ReefAngel.BuzzerOff();
// Lights under stand
if (!ReefAngel.IO.GetChannel(5)) {
ReefAngel.Relay.On(SumpLight);
} else {
ReefAngel.Relay.Off(SumpLight);
if (ReefAngel.IO.GetChannel(4)) {
ReefAngel.Relay.On(ControllerLight);
} else {
ReefAngel.Relay.Off(ControllerLight);
// Shut off the skimmer if the skimmate locker is full
if (ReefAngel.IO.GetChannel(3)) {
ReefAngel.Relay.On(Skimmer);
} else {
ReefAngel.Relay.Off(Skimmer);
// Feeding Mode Button
//if (!ReefAngel.IO.GetChannel(2) && ReefAngel.DisplayedMenu != FEEDING_MODE) {
// ReefAngel.FeedingModeStart();
// If the feeding mode button is pressed:
ReefAngel.CustomVar[7] = ReefAngel.IO.GetChannel(2);
ReefAngel.CustomVar[6] = ReefAngel.DisplayedMenu;
ReefAngel.Network.Cloud();
// * Utility Functions
boolean lightsAreOn () {
return actinicsOn() || daylightsOn();
boolean actinicsOn () {
return ReefAngel.Relay.Status(T5_Actinic);
boolean daylightsOn () {
return ReefAngel.Relay.Status(Kessil_A);
// RA_STRING1=...
// RA_STRING2=null
// RA_STRING3=null
