wifi expansion hub can't connect to cloud
Posted: Thu Apr 11, 2024 11:01 pm
by tngo
Hi
I have a wifi expansion hub but am having issues connecting it to the RA cloud. When setting up the expansion hub I use the same setup as the wifi attachment using 192.168.4.1 to setup the wifi and RA cloud login. However once I click save I only get a blinking magenta led meaning it's trying to connect to the RA cloud. My router picks up the expansion hub fine but I can't get past the blinking magenta led. I've tried using unencrypted username/password and encrypted username/password but no luck. Has anyone come across this problem or know what might be causing this? This issue started right around the time when I had to encrypt my password when using the webwizard.
Tim
Re: wifi expansion hub can't connect to cloud
Posted: Thu Apr 11, 2024 11:17 pm
by brennyn21
Hello, have you updated the device yet?
Posted: Thu Apr 11, 2024 11:19 pm
by brennyn21
Also the username and password should be non encrypted. It's also case sensitive
Posted: Fri Apr 12, 2024 8:15 am
by tngo
I didn't realize that there was and update for this hub. This should be the last device shown on the webwizard correct? I'll give that a try later today. Thanks for all the updates to the ReefAngel system.
Tim
by tngo
Tim
Posted: Fri Apr 12, 2024 1:34 pm
by brennyn21
For the hub there is a pin hole by the led light, hit that button while it's connected to the Internet and it will update. The Led should turn Yellow and it should work after that.
If you have any troubles let me know! The web wizard is only for very early versions of the cloud hub and cloud wifi module, it sounds like you have the later version of the module so you won't need it
by brennyn21
Posted: Fri Apr 12, 2024 8:48 pm
by tngo
I don't see the pin hole that you're referring to. I've attached an image of my board.
Tim
Posted: Fri Apr 12, 2024 8:59 pm
by brennyn21
Click on AP Reset while its connected to wifi and that will update the device
Posted: Fri Apr 12, 2024 10:10 pm
by tngo
Clicking on AP reset causes the hub to blink blue to begin the process to assign the ssid and cloud username and password. Once these are set and saved the hub goes back to blinking magenta.
Posted: Sat Apr 13, 2024 12:24 am
by brennyn21
You are hitting it when it's connected to WiFi and blinking magenta? So it's never turning yellow?
Posted: Sat Apr 13, 2024 7:30 am
by tngo
Yeah. I have hit the ap reset button many times over the past week trying to see if I could get the hub to connect. It may have updated then and i didn't notice, but the led isn't turning yellow now when I hit the button.
Posted: Sat Apr 13, 2024 9:03 am
by brennyn21
Let's try factory resetting it and see if that makes a difference. To do that you'll hold the ap Reset button while plugging in the power cable.
Posted: Sat Apr 13, 2024 1:54 pm
by tngo
I did the factory reset but after entering the wifi and cloud credentials the hub led still blinks magenta.
Posted: Sat Apr 13, 2024 1:58 pm
by brennyn21
Interesting... blinking magenta means issues with the user account. For the username you are using "tngo" all lowercase? And your forum password?
Posted: Sat Apr 13, 2024 2:33 pm
by tngo
Yes that is correct.
Posted: Sat Apr 13, 2024 2:46 pm
by tngo
The password is unencrypted correct?
Posted: Sat Apr 13, 2024 3:00 pm
by brennyn21
Yes just your normal forum password unencrypted. Case sensitive
Posted: Thu Apr 18, 2024 10:07 am
by javisaman
I believe I am having the same issue since April 11th with the magenta light. The uapp was working fine since then. However, I'm away from my tank for a few days and won't be able to debug. Is there a chance there is something wrong on the server end?
Posted: Thu Apr 18, 2024 11:09 am
by brennyn21
I am going through the logs to see if I can an issue. I will let you know
Posted: Thu Apr 18, 2024 7:52 pm
by javisaman
False alarm. I asked my parents to unplug it and plug it back in and its working now!
Posted: Fri Apr 19, 2024 12:48 am
by brennyn21
Glad to hear, I am making an adjustment to the reconnect function for the cloud WIFI attachment once, I have tested it thoroughly I will push it to the server.
