Custom Main Screen Font Problems
SuperDodge
Post by SuperDodge »
OK, here it is...another dumb question from the new guy...
I'm trying to create a custom main screen. I have read the pdf Curt created and feel like I have a really good handle on how to use it. My problem is that when I compile and upload to my RA, the fonts used don't seem to be the fonts I indicated.
As an example, I'll take the simplest line to see my point. I'm trying to write "Current USA Cardiff Reef" at the top of the screen in the default font. By my count this is 24 characters long. At 5 pixels wide per character that gives me a total length of 120 pixels. If I position this at x=5, y=2 I feel like it should be centered on the screen at the top of the screen.
In practice when I compile and upload my pde, the text runs off the screen. I see "Current USA Cardiff R". Can someone tell me what I am missing here?
Also, please note that when I attemp to use the 12x16 font, it appears to me that it is 16x16 when displayed on the screen.
I know that I'm probably doing something monumentally stupid, so I've attached my current PDE file below and a picture of my hideous screen.
// This version designed for development libraries v0.8.5 Beta 17 or later
#define DisplayImages
#define DisplayLEDPWM
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES  3
#define CUSTOM_MAIN
#define FONT_8x8
#define NUMBERS_12x16
#define AI_LED
//The following files are included when compiling:
#include <ReefAngel_Colors.h>
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_AI.h>
//Begin Initalize Variables
byte WhiteValue=0;
byte BlueValue=0;
byte RoyalBlueValue=0;
byte vtechmode=1;
byte DayAge;
byte ThisPhase;
int JulianDate(int,int,int);
double MoonAge(int,int,int);
byte MoonState();
boolean ForceCloud=false;
//End Initalize Variables
//Start of Custom Menu Section
prog_char menu3_label[] PROGMEM = "Thunder Storm";
	menu1_label, menu2_label, menu3_label};
 void MenuEntry1()
   ReefAngel.FeedingModeStart();
  void MenuEntry2()
  void MenuEntry3()
  ReefAngel.LCD.DrawDate(6, 90);
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 20, 40, "ThunderStorm");
  ForceCloud=true;
//End of Custom Menu Section
//Begin of Function to Convert Numbers to Text Strings
void ConvertNumToString(char* string, int num, byte decimal)
  char temptxt[3];
  int Temp = num;
  if (Temp==0xFFFF) Temp=0;
  itoa(Temp/decimal,string,10);
  if (decimal>1)
    itoa(Temp%decimal,temptxt,10);
    strcat(string, ".");
    if (Temp%decimal<10 && decimal==100) strcat(string, "0");
    strcat(string, temptxt);
//End of Function to Convert Numbers to Text Strings
//Start Custom Screen Display Section
  char text[7];
  ReefAngel.LCD.DrawHugeText(COLOR_PURPLE, COLOR_WHITE, 2, 12, text, Num12x16);
  ReefAngel.LCD.DrawText(COLOR_PURPLE, COLOR_WHITE, 51, 12, "degF tank temp");
  ReefAngel.LCD.DrawText(COLOR_DARKORANGE, COLOR_WHITE, 9, 38, "the tank pH is");
  ReefAngel.LCD.DrawHugeText(COLOR_DARKORANGE, COLOR_WHITE, 80, 30, text, Num12x16);
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 47, 132, 47);
  ReefAngel.LCD.DrawText(COLOR_DARKSEAGREEN, COLOR_WHITE, 28, 49, "Room Temp:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, COLOR_DARKSEAGREEN, 82, 49, 2);
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 58, 132, 58);
  ReefAngel.LCD.Clear(COLOR_LIGHTGRAY, 1, 59, 132, 77);
  ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_LIGHTGRAY, 10, 60, "Current EcoSmart Mode:");
  //Begin EcoSmart Mode Display Section
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, COLOR_LIGHTGRAY, 33, 69, "Constant", Font8x8);
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD, COLOR_LIGHTGRAY, 41, 69, "Lagoon", Font8x8);
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD, COLOR_LIGHTGRAY, 25, 69, "Reef Crest", Font8x8);
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, COLOR_LIGHTGRAY, 21, 69, "Short Pulse", Font8x8);
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK, COLOR_LIGHTGRAY, 25, 69, "Long Pulse", Font8x8);
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA, COLOR_LIGHTGRAY, 1, 69, "Nutrient Trnsprt", Font8x8);
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA, COLOR_LIGHTGRAY, 21, 69, "Tidal Swell", Font8x8);
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE, COLOR_LIGHTGRAY, 45, 69, "Night", Font8x8);
  //End EcoSmart Mode Display Section
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 78, 132, 78);
  //Begin Moon Phase Display Section
  DayAge = MoonAge(day(), month(), year());
  MoonState(DayAge);
  if (ThisPhase == 0)
    ReefAngel.LCD.DrawText(COLOR_DARKSEAGREEN, COLOR_WHITE, 45, 89, "Moon:");
    ReefAngel.LCD.DrawText(COLOR_DARKSEAGREEN, COLOR_WHITE, 70, 89, "New");
  else if (ThisPhase == 1)
    ReefAngel.LCD.DrawText(COLOR_DARKSEAGREEN, COLOR_WHITE, 15, 89, "Moon:");
    ReefAngel.LCD.DrawText(COLOR_DARKSEAGREEN, COLOR_WHITE, 40, 89, "Waxing Crescent");
  else if (ThisPhase == 2)
    ReefAngel.LCD.DrawText(COLOR_DARKSEAGREEN, COLOR_WHITE, 20, 89, "Moon:");
    ReefAngel.LCD.DrawText(COLOR_DARKSEAGREEN, COLOR_WHITE, 45, 89, "First Quarter");
  else if (ThisPhase == 3)
    ReefAngel.LCD.DrawText(COLOR_DARKSEAGREEN, COLOR_WHITE, 16, 89, "Moon:");
    ReefAngel.LCD.DrawText(COLOR_DARKSEAGREEN, COLOR_WHITE, 43, 89, "Waxing Gibbous");
  else if (ThisPhase == 4)
    ReefAngel.LCD.DrawText(COLOR_DARKSEAGREEN, COLOR_WHITE, 41, 89, "Moon:");
    ReefAngel.LCD.DrawText(COLOR_DARKSEAGREEN, COLOR_WHITE, 68, 89, "Full");
  else if (ThisPhase == 5)
    ReefAngel.LCD.DrawText(COLOR_DARKSEAGREEN, COLOR_WHITE, 43, 89, "Waning Gibbous");
  else if (ThisPhase == 6)
    ReefAngel.LCD.DrawText(COLOR_DARKSEAGREEN, COLOR_WHITE, 21, 89, "Moon:");
    ReefAngel.LCD.DrawText(COLOR_DARKSEAGREEN, COLOR_WHITE, 47, 89, "Last Quarter");
  else if (ThisPhase == 7)
    ReefAngel.LCD.DrawText(COLOR_DARKSEAGREEN, COLOR_WHITE, 40, 89, "Waning Crescent");
  //End Moon Phase Display Section
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 98, 132, 105);
  //Begin of AquaIllumination Channel Display Section
  ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_BLACK, 5, 98, "W:");
  if (WhiteValue < 10)
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.AI.GetChannel(0), COLOR_WHITE, 25, 98, 0);
  else if (WhiteValue < 100)
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.AI.GetChannel(0), COLOR_WHITE, 20, 98, 0);
  else if (WhiteValue == 100)
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.AI.GetChannel(0), COLOR_WHITE, 15, 98, 0);
  ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_BLACK, 30, 98, "%");
  ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_BLACK, 50, 98, "B:");
  if (BlueValue < 10)
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.AI.GetChannel(1), COLOR_BLUE, 70, 98, 0);
  else if (BlueValue < 100)
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.AI.GetChannel(1), COLOR_BLUE, 65, 98, 0);
  else if (BlueValue == 100)
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.AI.GetChannel(1), COLOR_BLUE, 60, 98, 0);
  ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_BLACK, 75, 98, "%");
  ReefAngel.LCD.DrawText(COLOR_ROYALBLUE, COLOR_BLACK, 95, 98, "R:");
  if (RoyalBlueValue < 10)
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.AI.GetChannel(2), COLOR_ROYALBLUE, 115, 98, 0);
  else if (RoyalBlueValue < 100)
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.AI.GetChannel(2), COLOR_ROYALBLUE, 110, 98, 0);
  else if (RoyalBlueValue == 100)
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.AI.GetChannel(2), COLOR_ROYALBLUE, 105, 98, 0);
  ReefAngel.LCD.DrawText(COLOR_ROYALBLUE, COLOR_BLACK, 120, 98, "%");
  //End of AquaIllumination Channel Display Section
  //Begin of Outlet Box and Date Display Section
  ReefAngel.LCD.DrawOutletBox(13, 107, TempRelay);
  ReefAngel.LCD.DrawDate(10, 120);
  //End of Outlet Box and Date Display Section
//End Custom Screen Display Section
//Begin custom Graph Function
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 1, 132, 10);
  ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_BLACK, 5, 2, "Current USA Cardiff Reef");
//End Custom Graph Function
//Begin Cloud and Thunderstorm Function
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(12,00)
#define End_Cloud_Before NumMins(19,00)
#define Lightning_Chance_per_Cloud 10
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
  // In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the 250 minutes (or 500 minutes) can fit in that 510
minutes window.
//#define forcecloudcalculation // Uncomment this to force the cloud calculation to happen in the boot process.
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
        // if picked number is greater than Lightning_Chance_per_Cloud, we will not have lightning today
        if (lightningchance>Lightning_Chance_per_Cloud) lightningchance=0;
  if (ForceCloud)
  ForceCloud=false;
  cloudchance=1;
  cloudduration=10;
  lightningchance=1;
  cloudstart=NumMins(hour(),minute())+1;
  if (cloudchance)
    //is it time for cloud yet?
      WhiteValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,WhiteValue,0,180);
        else lightningstatus=0;
        if (lightningstatus)
          WhiteValue=100;
          BlueValue=100;
          RoyalBlueValue=100;
          WhiteValue=0;
          BlueValue=0;
          RoyalBlueValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
cloudstart=random(Start_Cloud_After+(((End_Cloud_Before-Start_Cloud_After)/(numclouds*2))*cloudindex*2),(Start_Cloud_After+(((End_Cloud_Before-Start_Cloud_Af
ter)/(numclouds*2))*cloudindex*2))+((End_Cloud_Before-Start_Cloud_After)/(numclouds*2)));
    //ReefAngel.LCD.Clear(255,0,120,132,132);
    //ReefAngel.LCD.DrawText(0,255,5,120,"C");
    //ReefAngel.LCD.DrawText(0,255,11,120,"00:00");
    //ReefAngel.LCD.DrawText(0,255,45,120,"L");
    //ReefAngel.LCD.DrawText(0,255,51,120,"00:00");
      int x=0;
      else x=17;
      else x=35;
    if (lightningchance)
      int x=0;
      else x=57;
      else x=75;
      //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
//End Cloud and Thunderstorm Function
//Begin One Time Setup functions
    ReefAngel.AI.SetPort(daylightPWMPin);  //Define where the AI Nano is plugged in
    ReefAngel.Relay.On(Port2);  //Port 2 is the circulation pump
    ReefAngel.Relay.On(Port4);  //Port 4 is the skimmer
//End One Time Setup Functions
//Begin Main Program Loop
    // Define Which Ports Use Which Standard Functions
      ReefAngel.StandardHeater(Port1);  //This is the Main Display Heater
      ReefAngel.DosingPump1(Port8);  //Dosing Pump 1 is the Alkalinity Pump
      ReefAngel.DosingPump2(Port7);  //Dosing Pump 2 is the Calcium Pump
      ReefAngel.ShowInterface();  //Draw the Standard Interface
    //Audible Alarm Control Scheme
      if (ReefAngel.Params.Temp1>810)  //If the water temperature exceeds 81F
        ReefAngel.PWM.SetActinic(100);  //Sound the alarm
        if (ReefAngel.Params.Temp1<770)  //If the water temperature is less than 77F
          ReefAngel.PWM.SetActinic(0);  //Silence the alarm
    //End of Audible Alarm Control Scheme
    //AquaIllumination Nano Control Scheme
      if (hour()>=22 || hour()<9)
        WhiteValue=0;
        BlueValue=MoonPhase()*0.06;
        RoyalBlueValue=MoonPhase()*0.06;
        ReefAngel.AI.SetChannel(White,WhiteValue);
        ReefAngel.AI.SetChannel(Blue,BlueValue);
        ReefAngel.AI.SetChannel(RoyalBlue,RoyalBlueValue);
        WhiteValue=PWMSlope(9,0,22,0,0,100,180,0);
        BlueValue=PWMSlope(9,0,22,0,6,100,120,MoonPhase()*0.06);
        RoyalBlueValue=PWMSlope(9,0,22,0,6,100,120,MoonPhase()*0.06);
        CheckCloud();
    //End of AquaIllumination Nano Control Scheme
//End of Main Program Loop
//Begin of Section to Calculate Moon Phase
int JulianDate(int d, int m, int y)
  int mm, yy;
  int k1, k2, k3;
  int j;
  yy = y - (int)((12 - m) / 10);
  mm = m + 9;
  if (mm >= 12)
    mm = mm - 12;
  k1 = (int)(365.25 * (yy + 4712));
  k2 = (int)(30.6001 * mm + 0.5);
  k3 = (int)((int)((yy / 100) + 49) * 0.75) - 38;
  // 'j' for dates in Julian calendar:
  j = k1 + k2 + d + 59;
  if (j > 2299160)
    // For Gregorian calendar:
    j = j - k3; // 'j' is the Julian date at 12h UT (Universal Time)
  return j;
double MoonAge(int d, int m, int y)
    int j = JulianDate(d, m, y);
    //Calculate the approximate phase of the moon
    int ip = (j + 4.867) / 29.53059;
    ip = ip - abs(ip);
    //After several trials I've seen to add the following lines,
    //which gave the result was not bad
    if(ip < 0.5)
        int ag = ip * 29.53059 + 29.53059 / 2;
        int ag = ip * 29.53059 - 29.53059 / 2;
    // Moon's age in days
    byte ag = abs(ag) + 1;
    return ag;
byte MoonState(byte D)
  switch(D){
  case 1:
    0, 29;
    ThisPhase = 0;
  case 2:
    1, 2, 3, 4, 5, 6;
    ThisPhase = 1;
  case 3:
    7;
    ThisPhase = 2;
  case 4:
    8, 9, 10, 11, 12, 13;
    ThisPhase = 3;
  case 5:
    14;
    ThisPhase = 4;
  case 6:
    15, 16, 17, 18, 19, 20, 21;
    ThisPhase = 5;
  case 7:
    22;
    ThisPhase = 6;
  case 8:
    23, 24, 25, 26, 27, 28;
    ThisPhase = 7;
  default:
    return 0;
//End of Section to Calculate Moon Phase
Re: Custom Main Screen Font Problems
Well, I think each character you use is 5x8, but it needs one pixel to separate each letter, so in fact each character uses 6 pixels.
SuperDodge
rimai wrote:Well, I think each character you use is 5x8, but it needs one pixel to separate each letter, so in fact each character uses 6 pixels.
That would explain the problem with the banner.
Is the one pixel spacing consistent with all fonts or is the spacing larger if I'm using the 12x16 font for instance?
Also, I'd recommend this spacing get added to the font description table in Curt's VERY EXCELLENT pdf on custom main screens.
I'm updating the formulas in the excel spreadsheet I created to calculate pixel positions for me to reflect the space so that I can properly center everything.
To be honest, I never user the large fonts :(
I'll have to look in the code to see what it does, but I'd assume so.
Yeah, I'm pretty sure the spacing is consistent with all fonts. In fact, to determine the spacing, I literally tested out the fonts on the display and would count the width of the letters and the number of letters. I even used zoom on my digital camera to count the pixels. :) I wanted to get it right.
Thanks for the suggestion. I have to update the pdf to be consistent with the new libraries (header file changes). I'll double check the spacing and make a comment on it. Plus I'll await to see what you found out. I do know that the pdf has how many characters can fit on the screen with each font.
SuperDodge
The spacing has to be more than one pixel on the larger fonts because your table says you can only fit 8 12x16 characters on a line (and if it was a single pixel space you would be able to do 9). I missed the characters per space line before and assumed the space between characters was included in the width (which is clearly my mistake).
I'll play with my PDE file and try to make sure I get the spacing just right when I get home tonight. I'll make a new post with exactly what I figure out so you can update your pdf if you see fit.
I'll also post the simple excel spreadsheet I made that does the math for people and calculates screen positions if they want.
SuperDodge
Here's a link to the excel file I used to help me center all my codes more easily.
The first worksheet is where you type in your text strings (or representative monitor output) and get back the x position you need to center your line.
-All cells with blue text are inputs, the others are calculated.
-All items with the same "Line #" value are assumed to go on the same line with a single pixel space between them. The excel file will automatically put borders between groups with the same "Line #"
-Click in the "Font Name" cell for a drop down box to appear and you can select which font you wish to use for that text string.
-I have turned on excel protection to prevent someone from accidentally over-writing a formula; however, there is no password so it can easily be turned off if someone wants to modify the file.
The second worksheet is just a 128x128 map that I used to approximate what my screen would look like
Happy Custom Screening!
http://dl.dropbox.com/u/1600831/Reef_An ... Layout.xls
TanksNStuff
Post by TanksNStuff »
Nice Spreadsheet SuperDodge. I just have one question about it though... The "Font_12x16" only has a 1 pixel space between chars, but the "Numbers_12x16" has 3 pixel space? I haven't checked to verify this myself, but that doesn't seem like it should be correct. Did you verify this?
SuperDodge
TanksNStuff wrote:Nice Spreadsheet SuperDodge. I just have one question about it though... The "Font_12x16" only has a 1 pixel space between chars, but the "Numbers_12x16" has 3 pixel space? I haven't checked to verify this myself, but that doesn't seem like it should be correct. Did you verify this?
You're right. The font and the numbers are the same, I just missed updating the table for the font because I wasn't using it.
I'll update the spreadsheet when I get to work tomorrow. The download link will remain the same.
SuperDodge
Update: I've confirmed using a magnifying glass that Font_8x8 and Numbers_8x8 are actually 7 pixels wide with a single pixel space. I'll update the spreadsheet to reflect this change as well.
