Can no longer connect to uapp
Posted: Thu Jun 20, 2024 3:02 pm
by Reefology
hi, I haven't needed to access my controller in some time and today when I went to login, it looks different and my controller is no longer listed. I get the "login failed, user not found" error.
in the settings, I used to have to input my local ip and port to connect, but even that has changed! how do I login?
thanks
Re: Can no longer connect to uapp
Posted: Thu Jun 20, 2024 3:30 pm
by brennyn21
If you have the RA Plus and the older wifi attachment you'll need to reupload your code as well as update your wifi attachement.
For the wifi attachment download the zip folder below with the file and instructions.
firmware/updatewifi.zip
You will also need reupload your code to the raplus using the webwizard.
Here is a more detailed instructions.
instructions/migrationinstructions.pdf
Let me know if you need any other assistance.
